BT Speedtester
- Re: BT Speedtester
BT Speedtester
27-09-2012 3:25 PM
How much data is downloaded in order to carry out the speed test?
Message 1 of 8
(1,464 Views)
7 REPLIES 7
Re: BT Speedtester
27-09-2012 5:22 PM
Hi Finch,
Whilst I don't have an exact figure I can confirm that the amount of usage the BT speed tester uses when running a test in minimal in comparison to your monthly peak time download allowance. The only way to find out for sure would be to run the BT speed tester whilst running a usage monitoring tool (something like this: http://www.thinkbroadband.com/tbbmeter.html ) with as few background processes and programs running as possible so as not to skew the result.
I would be surprised if the usage was more than a couple of megabytes.
Message 2 of 8
(743 Views)
Re: BT Speedtester
27-09-2012 5:32 PM
I have just checked and it was under 2MB download and 1.5MB upload
Message 3 of 8
(743 Views)
Re: BT Speedtester
27-09-2012 7:12 PM
Thanks guys. I'm new to Plusnet (install yesterday) and am keeping tracks on my usage now that I can enjoy an FTTC connection. My old connection for the last 10 years was less than 1Mb, so I want to make sure I don't go overboard with my usage !!! Cheers.
Message 4 of 8
(743 Views)
Re: BT Speedtester
27-09-2012 7:17 PM
Very wise.You know about VMBU (login required) I assume?
Message 5 of 8
(743 Views)
Re: BT Speedtester
28-09-2012 12:21 AM
Yes I do, and what a useful tool, but thanks anyway !!
Message 6 of 8
(744 Views)
Re: BT Speedtester
01-10-2012 12:48 PM
You're welcome. And welcome to Plusnet and the Forums by the way.
Message 7 of 8
(744 Views)
Re: BT Speedtester
01-10-2012 1:41 PM
I believe the BT speedtester runs the download for a fixed time (about 15 seconds) so the data used will depend on the speed of the line.
Call me 'w23'
Message 8 of 8
(744 Views)
