BT Speedtester problems
- Re: BT Speedtester problems
10-03-2008 11:00 AM
Hi all,
On trying to use the BT Speedtester over the course of the last few days I have found that when the actual test commences it comes up with a notice "Exception - permission denied". The progress bar then runs to 96% after which it stalls and the test results do not appear. Has anyone else encountered this problem, and if so is there a means of overcoming it?
Many thanks for any help you can provide.
Regards,
Davidhil.
Regards,
Davidhil.
Message 1 of 8
(1,717 Views)
7 REPLIES 7
10-03-2008 6:54 PM
You're not the only one. I've been trying to run the BT speedtest since Friday night and get exactly the same problem!
Message 2 of 8
(641 Views)
10-03-2008 7:12 PM
Do you mean like this?
Note the Java exception message.
This is a long-standing error.
The only way to overcome this error is not to use this website.
Despite what BT say, it is broken.
Message 3 of 8
(641 Views)
10-03-2008 9:21 PM
Been getting the exact same error message with Firefox---- never works.
Strange thing is if i try the BT speedtest with Opera it completes almost every time, no java error
Message 4 of 8
(641 Views)
10-03-2008 9:40 PM
what this then
Message 5 of 8
(641 Views)
11-03-2008 11:18 AM
Hi all,
Just thought I should add a further post. I have found that if I switch off my Firewall, ( Norton Internet Security for Macintosh), whilst running the last part of the test then it will complete and provide it's normal readings. I have run the test on Opera but find it does not work but it's OK on Safari and Firefox.
Regards,
Davidhil
Regards,
Davidhil
Message 6 of 8
(641 Views)
11-03-2008 12:08 PM
It never works for me in Firefox but very nearly always works for me in IE.
Message 7 of 8
(641 Views)
11-03-2008 1:15 PM
I really think its about time BT pulled their finger out, and sorted this tester. If they want us to run tests using this pathetic excuse of an application, before they accept there is a fault, then they should make sure it actually works. I am sure PlusNet and other ISPs are pushing as they are probably sick of this as well. Do plus have any comment on what Bt are doing if anything about this Speedtester.
Message 8 of 8
(641 Views)
