BT Speedtester - is it broken?
- BT Speedtester - is it broken?
Re: BT Speedtester - is it broken?
13-09-2010 4:15 PM
13-09-2010 7:55 PM
Quote from: Joanne @dave and jim,
can I ask you both to run the speed tests at speedtester.bt.com and then www.speedtester.com and see if the results match. I've been doing some troubleshooting but there are no reported faults with it and these 2 url's although they are supposed to be the same may give different results on 21CN, so, guys, I'd appreciate your help on this one.
Jojo
Jojo
speedtester.bt.com gives the result attached. I also attach the result from www.mybroadbandspeed.co.uk
My router stats shortly after the test are:
Uptime: 0 days, 6:40:16
DSL Type: G.992.5 annex A
Bandwidth (Up/Down)
[kbps/kbps]: 444 / 19,690
Data Transferred
(Sent/Received)
[kB/kB]: 0.00 / 0.00
Output Power (Up/Down) [dBm]: 11.5 / 0.0
Line Attenuation (Up/Down) [dB]: 7.5 / 16.0
SN Margin (Up/Down) [dB]: 30.0 / 5.5
Vendor ID
(Local/Remote): TMMB / IFTN
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 13,460
CRC Errors (Up/Down): 0 / 4
HEC Errors (Up/Down): 0 / 4
It seems to have reset itself during the day.
I couldn't work out what to do at your other URL
Dave
14-09-2010 11:21 AM
I did want 2 bt tests though. 1 from speedtester.bt.com which you've done, and another one from www.speedtester.bt.com
Jojo
14-09-2010 11:24 AM
14-09-2010 12:52 PM
Both those URLs point to the same pair of IP addresses:
Addresses: 217.35.209.142
217.32.105.42
217.32.105.42
So, I guess that it may be that the two servers give different results.
I can try both tonight if you want.
Dave
14-09-2010 12:58 PM
http://217.32.105.42:50301/ failed on the upload test
http://217.35.209.142/ gave this result
14-09-2010 1:28 PM
I need a few examples, so just if dave does that for me I'll be able to take it further.
Jojo
14-09-2010 8:35 PM
Two test results attached
Both somewhat peculiar
Dave
15-09-2010 9:37 AM
Thank you for all your help. With the examples you have provided I have now raised a problem (63490) So, as soon as I know anymore I"ll update you all.
thanks again,
Jojo
15-09-2010 11:29 AM
15-09-2010 12:00 PM
Like others, I've found that the results don't make sense. I just hope that my IP profiles are being wrongly stated. It claims my downstream profile is 5500, when the Plusnet IP profile is given as 7150 (correct for my current sync speed of 8279) and that my upstream profile is 448, when I'm on an uncapped upstream connection (with a sync speed of 800).
I wouldn't worry, as we know the speedtester isn't working properly at the moment - except that my current downstream throughput is pretty slow - between 3800 and 4200 according to a few PN broadband speed tests a couple of minutes ago. I hope that's just congestion somewhere.
Graham
16-09-2010 5:08 PM
One peculiarity I have noticed is that on occasion, an error is thrown relating to the username being invalid (didn't write down the exact error), but it will be a different username to my own, e.g. some.guy@btinternet.com. As for others, I am no longer being prompted to enter a username either. It seems as if the speed tester is getting a bit confused and is actually returning somebody elses connection data, and then comparing that to your own test results.
I'm on 21CN.
16-09-2010 7:33 PM
Download speedachieved during the test was - 6379 Kbps
For your connection, the acceptable range of speedsis 2000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :3184 Kbps(DOWN-STREAM), 468 Kbps(UP-STREAM)
IP Profile for your line is - 14000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 9.02:31.53:59.45 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Upload Speed
361 Kbps
0 Kbps 468 Kbps
Max Achievable Speed
>Upload speed achieved during the test was - 361 Kbps
Upstream Rate IP profile on your line is - 468 Kbps
17-09-2010 12:58 PM
18-09-2010 12:20 PM
