BT Speedtester - is it broken?
- BT Speedtester - is it broken?
12-09-2010 9:11 PM
Just to clarify - these are my current stats
ADSL Link Downstream Upstream
Connection Speed 4288 kbps 448 kbps
Line Attenuation 51.0 db 21.5 db
Noise Margin 4.6 db 24.0 db
Re: BT Speedtester - is it broken?
12-09-2010 9:22 PM
12-09-2010 9:39 PM
13-09-2010 12:23 PM
My actual download speed dropped sharply.
Dave
13-09-2010 1:08 PM
from what I can see your profile is 17000.
@all,
we are seeing a few strange speedtester results and I am having that looked into, so more to follow on that one.
Jojo
13-09-2010 3:05 PM
can I ask you both to run the speed tests at speedtester.bt.com and then www.speedtester.com and see if the results match. I've been doing some troubleshooting but there are no reported faults with it and these 2 url's although they are supposed to be the same may give different results on 21CN, so, guys, I'd appreciate your help on this one.
Jojo
13-09-2010 3:13 PM
I am at work at present but will try tonight
Dave
13-09-2010 3:15 PM
Jojo
13-09-2010 3:35 PM
Note I usually use http://217.35.209.142/ and http://217.32.105.42:50301/
13-09-2010 3:38 PM
13-09-2010 3:51 PM
@jaggies, hmmm, it is having its moments lately!
Jojo
13-09-2010 3:53 PM
Router reports:
Line state Connected
Connection time 1 days, 19:12:01
Downstream 16,532 Kbps
Upstream 1,120 Kbps
BT Speedtest result:
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
14328 Kbps
0 Kbps 21000 Kbps
Max Achievable Speed
Download speed achieved during the test was - 14328 Kbps
For your connection, the acceptable range of speeds is 2000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :8124 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 14000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 16.69:22.85:60.47 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Upload Speed
920 Kbps
0 Kbps 444 Kbps
Upload speed achieved during the test was - 920 Kbps
Upstream Rate IP profile on your line is - 444 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
13-09-2010 3:57 PM
13-09-2010 3:59 PM
Quote from: Joanne @dave and jim,
Jojo
Your link is taking me to the website attached below???
13-09-2010 4:08 PM
It asked for phone number - but not my account name.
It then did separate download and upload "tests".
It got both my Download and Upload DSL rates wrong.
Although, the actual upload/download rates appear to be only a bit on the low side.
