BT Speedtest Problem.
jojopillo
Re: BT Speedtest Problem.
You're welcome, I wonder why you can't get a result with the number.
Strat
Fixes: 565
Quote from: Joanne
Checked just now and this morning I can with good results.
Thanks Jojo Smiley
jojopillo
Ah good, thanks for that Smiley
JayG
Fixes: 6
Sorry to rain on the parade but although the BT Performance tester seems to be working first time for me, and "to completion" the results still seem to vary wildly compared with other testers.
Just ran Speedtest.net and got 9.30/0.98 (Mbps d/u), immediately followed by BT Performance tester (4.31/0.94) which in turn I immediately followed with MBS (9.30/1.01)
I wouldn't want this "diagnostic tool" in my toolbox at the moment!  Sad
FredCojones
I can't run the BT SpeedTester at all - it comes up with 'The Performance Tester is currently unable to run a speed test for your broadband connection. ...'. This has been the case for the last 2 weeks or so and has the same result on Chrome, Firefox and IE9. I've tried using both my phone number and Service Id. Any ideas?
w23
Fixes: 4
I got it running last night and this morning but when it completed the download and upload tests it redirected straight to the 'third test required' screen without displaying any results, my speeds are fine but I'd like to check my profile which it doesn't give me.  I have NEVER managed to complete a third test by the way, I have followed the instructions carefully but never seem to actually establish a connection.
For some reason the BE BRAS profile checked does not work for me on my home connection, oddly though I can enter my home number from work (on BT Business broadband) and it gives the correct details so I can check my BT profile on my home line if I'm at work!
Any idea why the BE checker would say 'Real Error: BT Error or not a BT or BT Wholesale Line Rental number'?  I assume that a Plus Net phone line is a BT Wholesale Line Rental number.  Maybe the error is just indicative of corruption in the BT speedtester system/database.
Call me 'w23'
Apprentice
The tester worked OK using the phone number a few minutes ago but the recorded throughput is poor, checked the exchange and the VPs are reported as being green.
orbrey
Thanks all, we'll get investigating and try and find out what's going on here. It's been raised internally and we'll keep you posted, update to follow as soon as we know more.
niko
its still getting stuck at 96% with my parents (also with plusnet)
jelv
Fixes: 10
It's just run OK for me (I'm 20CN).
I've also just run the Beta. It's come up with a latency of 79.11 which is absolute rubbish:
C:\Users\John>ping bbc.co.uk
Pinging bbc.co.uk [212.58.241.131] with 32 bytes of data:
Reply from 212.58.241.131: bytes=32 time=15ms TTL=246
Reply from 212.58.241.131: bytes=32 time=13ms TTL=246
Reply from 212.58.241.131: bytes=32 time=14ms TTL=246
Ping statistics for 212.58.241.131:
   Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
   Minimum = 13ms, Maximum = 15ms, Average = 14ms
Edit: I've also tried pinging back to myself from the office (on a totally different network) and got similar figures.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
JayG
Fixes: 6
This morning, in quick succession:
Speedtest.net : 9.30/0.99
BT : 8.15/1.04
MBS : 9.30/1.01
(I regard that as a "normal" result from the BT tester, but therein lies the problem - yesterday's 4.31 Mbps download speed looked equally "normal" but was only half the correct figure.)
colintivy
This afternoon and in quick succession here:-
BT Speedtester 2980/379  BUT download speed = 0Mbps ! (It did stick at 96%)  Profile 2500 Mbps.
MBS                3249/450
So BT relatively still weird I guess.
colintivy
This thread looks very similar to  alex7127 BTSpeedtester on page 1  does it not?
