BT Speed Tester not working.?
- BT Speed Tester not working.?
Re: BT Speed Tester not working.?
15-07-2012 11:44 AM
15-07-2012 12:12 PM
15-07-2012 2:51 PM
Quote from: mexicano Hi JoJo,
I'm also having trouble using the BT Speedtest.net. I have been trying to use it for about a week at various times of the day. All I get is the revolving java circle at the top of the page where it should say Performance Tester. I am using Windows 7 with Firefox 13.0.1 with the latest Java update. I have even tried installing several previous older versions of java but still nothing.
I am attaching a copy of the top of the speedtest.net page to show you what i get.
Hope it helps.
I uninstalled Zonealarm firewall this morning and then downloaded a fresh version from filehippo.com and the BT Speedtest is now working for me. I'm not sure if that was the problem but I'm ok now.
15-07-2012 3:05 PM
17-07-2012 10:49 PM
I have now managed to do more test on 2 other computers.
My findings are that :-
The ADSL part of the Diagnostics choice works OK
The FTTC part of the Diagnostics choice runs but does NOT complete in full.
Firewall and AV software both on or both disabled makes no difference.
The error message in the original post occurs after the FTTC tests are completed.
The versions of Browser, Java, etc. would not appear to be relevant;
and the various comments added to this thread do not show the service used,
i.e. is it FTTC or is it copper based ADSL.
As both options are combined on the one button it is down to the testing software to differentiate with FTTC failing and ADSL working.
The alternative test for up to 24Mbps (Beta) works OK.
If anyone else provides test results will you please note whether you are connected by FTTC or ADSL.
This could help to confirm that it is an FTTC only problem (or maybe not ?).
18-07-2012 12:10 AM
Prior to when we had to click on an update box a couple of months ago it worked perfectly every time.
I just hope Im not asked for the info by customer support anytime soon. I do use Kaspersky KIS 2011 but that has never been a problem in the past.
Pete
18-07-2012 10:30 AM
Might be worth checking if Java is up to date first, if it is then maybe try with Kaspersky turned off just to run the test and see if that makes any difference?
18-07-2012 10:33 AM
18-07-2012 10:36 AM
http://preview.tinyurl.com/bwe5m
18-07-2012 11:03 AM
18-07-2012 11:09 AM
I have never had to disable anything to get the speedtester to run, it does require the correct permissions for JavaRE in the Firewall, but if it runs in the first place you computer is ok. If after that it then gives errors, it's borked!
18-07-2012 12:47 PM
perhaps it has to be something to do with the useless bandwidth speed test plusnet use on Connection settings (http://www.mybroadbandspeed.co.uk/), its been shown as faulty for months.
Wonder why plusnet do not use the link to www.speedtest.net at least that works.
18-07-2012 1:25 PM
Did you get the option to use the BT beta tester and did that run (not the same as the Diagnostic one though)?
18-07-2012 3:35 PM
Thanks for all the advice, appreciated.
Pete
18-07-2012 3:56 PM
Beats me!! Computers, who needs 'em???
Thanks again.
Pete
