BT Speed Test
- BT Speed Test
BT Speed Test
26-09-2013 6:32 PM
Is it some thing wrong with my end or is it the test which has an issue? I am unable to fathom this out. Any help or comments will be appreciated.
Many regards,
Re: BT Speed Test
27-09-2013 9:57 AM
Re: BT Speed Test
27-09-2013 5:02 PM
Quote from: _Adam_Walker_ You might want to see if it behaves any differently using Internet Explorer.
Thanks Adam. I have tried with IE10 and it does not even run the short test - giving error 2032. So, it appears that there may something wrong with the tester.
Chandu.
Re: BT Speed Test
04-10-2013 6:09 PM
I have responded to your suggestion of trying to use IE, which did not work at all. May be you guys are very busy to respond to my query about BT speed test. I will appreciate some feedback so I can use the tester with detailed diagnostic.
Regards,
Chandu.
Re: BT Speed Test
05-10-2013 11:09 AM
Re: BT Speed Test
05-10-2013 1:00 PM
Quote from: wykehamhouse If I was you, I'd leave it a couple of days and then try again. If it still doesn't work, then please post back.
Thanks for your help. Originally I had posted this issue on 26/9/13 and have left it for so long and still it does not work. So, either the diagnostic test is broken or my Firefox is causing the issue. Having said that I have tried the test using IE10 but it was worst, it gave me an error 2032 on basic speed test leave alone the detailed diagnostic test. So, it appears that something is not right.
Re: BT Speed Test
05-10-2013 1:03 PM
Re: BT Speed Test
05-10-2013 4:58 PM
Quote from: wykehamhouse Can you try it on another PC?
Yes, I have already tried it with a desktop with WinXP, again using FF. Same result. So, it appears that there is gremlin somewhere - but where?
Chandu.
Re: BT Speed Test
05-10-2013 5:39 PM
Re: BT Speed Test
06-10-2013 12:20 PM
Quote from: Susie By ethernet or wireless?
By wi-fi, as my master socket is by front door. Until a month ago, it used to work fine.
Chandu
Re: BT Speed Test
06-10-2013 12:32 PM
Re: BT Speed Test
06-10-2013 3:22 PM
Quote from: chandu By wi-fi, as my master socket is by front door. Until a month ago, it used to work fine.
Try it again via a wired connection.
Re: BT Speed Test
06-10-2013 6:51 PM
Panic over!!! I just found out why the FURTHER DIAGNOSTIC part did not work. I had keyed-in my telephone number incorrectly (2 digits, in the middle, were swapped). Sorry!!!
Thank you all for your help and my sincere apologies. I must be getting dyslexic in my old age!!!!
Many regards,
Chandu.
