BT Speed Test History?
- Re: BT Speed Test History?
25-01-2010 3:38 PM
Having read a lot of posts about speed issues, and having eventually got my own speed sorted out. I wonder if there is a case to be made for making a regular (say, once a week) BT speed test....
As I understand it, the results are logged by both BT and Plusnet, and the information suppled at BT end, is used as part of any "fault finding/recovery" process.
If regular speed tests are carried out by customers, then a "history" would also be available, to the "technical" bods that could possibly help to resolve the problems (if any) more quickly.....
Can anyone advise if this is a good idea?
(not sure if it should be here or in another place..... please move if needed!)
Message 1 of 3
(790 Views)
2 REPLIES 2
25-01-2010 3:41 PM
Personally I think it's not a bad idea, I've suggested similar things previously. However it's worth noting that the results aren't logged by us, we can obtain them via a linetest but it only shows the most recent few IIRC.
Message 2 of 3
(360 Views)
25-01-2010 3:45 PM
OK.... then I shall continue to do it .... probably every Monday morning.... when it is busy ! ! ....
Message 3 of 3
(360 Views)
