BT Home Hub 5
- BT Home Hub 5
Re: BT Home Hub 5
29-11-2013 1:00 PM
Re: BT Home Hub 5
29-11-2013 1:07 PM
Re: BT Home Hub 5
29-11-2013 1:09 PM
Re: BT Home Hub 5
29-11-2013 4:16 PM
Re: BT Home Hub 5
29-11-2013 5:21 PM
http://btsupport.custhelp.com/ci/fattach/get/3309418/1381227399/redirect/1/session/L2F2LzEvdGltZS8xM...
Re: BT Home Hub 5
29-11-2013 6:59 PM
Re: BT Home Hub 5
20-01-2014 11:08 PM
Re: BT Home Hub 5
22-01-2014 10:40 AM
I set up today, both wired and wireless devices, which was relatively simple except that I could not get a wireless connection between my printer (Canon MG6450) and the Hub using the WPS button on the Hub. It had connected to my technicolor router easily. I eventually found a way to put the Hub access code into the printer manually.
My download and upload speeds are virtually identical ( FTTP), as would be expected.
One slight downside is that there is (as far as I can see) just one activity light (no separate lights for power, ethernet, broadband, internet (as on technicolor) or power, DSL LAN (as on modem))
Re: BT Home Hub 5
22-01-2014 1:37 PM
Quote from: kelvin One slight downside is that there is (as far as I can see) just one activity light (no separate lights for power, ethernet, broadband, internet (as on technicolor) or power, DSL LAN (as on modem))
I believe they flash differently and have different colours for different statuses.
Ex-Broadband Service Manager
Re: BT Home Hub 5
22-01-2014 2:34 PM
It was easy to set up and I am happy.
My speed increased with the BT hub
Oh software upgrade was automatic.
Re: BT Home Hub 5
22-01-2014 2:38 PM
Re: BT Home Hub 5
22-01-2014 6:19 PM
Re: BT Home Hub 5
22-01-2014 7:35 PM
Re: BT Home Hub 5
22-01-2014 11:07 PM
I will monitor over the next week or so before spending more money on a wi fi extender
Re: BT Home Hub 5
23-01-2014 3:15 PM
"The Broadband username that you’ve entered is either incorrect or is not supported by your BT Home Hub. Please check your username and try again."
From all the posts here I thought it worked just fine ...
Dave Partridge
