BT Home Hub 5
- Re: BT Home Hub 5
BT Home Hub 5
26-08-2014 7:57 PM
I think BT Home Hub 5 had finally fixed, no more rebooting issues!
1. Product name: BT Home Hub
2. Serial number: *******************************
3. Firmware version: Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 03/07/14
4. Board version: BT Hub 5A
5. VDSL uptime: 4 days, 16:12:44
6. Data rate: 19999 / 79995
7. Maximum data rate: 38145 / 103344
8. Noise margin: 15.0 / 13.6
9. Line attenuation: 0.0 / 11.3
10. Signal attenuation: 0.0 / 11.3
Message 1 of 6
(1,078 Views)
5 REPLIES 5
Re: BT Home Hub 5
26-08-2014 8:11 PM
Let's hope so. You won't have to keep posting so much about problems then, or about the BT speedtester not working as you won't have a real need to use it so often
Message 2 of 6
(714 Views)
Re: BT Home Hub 5
26-08-2014 8:44 PM
Am I correct if Noise Margin target 6dB will get maximum sync rate speed just like ADSL2+ did?
Message 3 of 6
(714 Views)
Re: BT Home Hub 5
26-08-2014 8:48 PM
That really isn't a good comparison
Think of it as being the same as MaxDSL with speeds limited to 8128/448 and once you hit those the higher reported noise margin the better
Message 4 of 6
(714 Views)
Re: BT Home Hub 5
26-08-2014 9:05 PM
So, a noise margin of 13.6 is plenty of roomy left for maximum VDSL 80Mbps?
Message 5 of 6
(714 Views)
Re: BT Home Hub 5
26-08-2014 9:23 PM
Yes it ought to be but vDSL is a strange and complex beast.
Message 6 of 6
(714 Views)
