BT Home Hub 4 & Fibre Broadband
jslane
Will the Home Hub 4 be ok for fibre broadband? I'm guessing/hoping Openreach will install a modem near it, or should I have ordered the router plusnet were giving us? We didn't really want to order another router since the HH4 has been great.
This is for my parents account - just in case someone from plusnet sees this and wonders where the order is on my account Tongue (my cabinet isn't FTTC enabled :'()
5 REPLIES 5
Jaggies
Re: BT Home Hub 4 & Fibre Broadband
It will be fine. You just need to put in your Plusnet user details.
http://community.plus.net/library/hardware/using-a-bt-homehub-3-or-2-on-plusnet-adsl-or-fttc/
jslane
Thanks! Smiley
gmcgough600
Did it work?
spraxyt
Resting Legend
Fixes: 75
This topic is over 3 years old. At the time the answer was probably "yes" because FTTC fibre installs involved a home visit where the BT engineer provided a filtered faceplate adaptor and VDLS2 modem to which the Home Hub 4 connected.
That is no longer the case and since HH 4s don't include a VDSL2 modem it would not work (without the missing extras being sourced from elsewhere).
David
Fixes: 1,483
Moderators Note.
Old topic locked, if any further help is required start a new topic as things have moved on since then.
