BT HUB 5
- Re: BT HUB 5
BT HUB 5
05-10-2014 6:42 PM
Re: BT HUB 5
05-10-2014 6:46 PM
Re: BT HUB 5
05-10-2014 8:32 PM
Some people say it does work but like me it did not work for me, so you are taking a risk on purchasing this and then finding out that it will not work with a Plusnet connection.
Re: BT HUB 5
05-10-2014 9:09 PM
Re: BT HUB 5
06-10-2014 8:03 AM
Quote from: SWebster This contradicts what I was told by an Openreach engineer. I had my fibre installed and I did not have a router, to I asked the engineer if he had any on the van and he produced a BT HomeHub 5, which he plugged in and it would not work. He connected it and then it connected for seconds to the signal and kept dropping the signal and would not work and apparently there was something going on with the router that was not allowing Plusnet to work.
it was either faulty router or he didn't configure it correctly to work with plusnet.
Re: BT HUB 5
06-10-2014 2:18 PM
If I had know that all I needed to do was configure it, I would have asked him to leave it, but since then I have the Openreach modem and Technicolor router that seems to be working okay.
Re: BT HUB 5
06-10-2014 3:27 PM
Re: BT HUB 5
06-10-2014 3:51 PM
Sometimes they become unstable after the software update but a factory reset seems to fix it.
Mine has been up for 18 days and counting
Regards, David
Re: BT HUB 5
06-10-2014 5:07 PM
Wireless is so much better than with the Plusnet supplied router
Re: BT HUB 5
06-10-2014 5:25 PM
Re: BT HUB 5
06-10-2014 7:25 PM
Re: BT HUB 5
06-10-2014 7:46 PM
Re: BT HUB 5
06-10-2014 7:51 PM
Re: BT HUB 5
06-10-2014 8:22 PM
Re: BT HUB 5
06-10-2014 9:37 PM
