BBYW opt 1 Question
- BBYW opt 1 Question
BBYW opt 1 Question
21-08-2007 12:28 AM
Hi All,
i know this has been asked when PN launched there new look products but it would take ages to schroll through the old forum.
i was going to recommend broaband your way option 1 to someone when i noticed that it only came with a 1gb download and no vpn support.
i thought it came with at least 2gb download (was going to get the to take a further 3 or 4 gb's ) and the vpn decision was changed within a week after launching becuase of all the queries raised on the old forum.
is the product page out of date or do i have the wrong info?
Message 1 of 5
(1,823 Views)
4 REPLIES 4
Re: BBYW opt 1 Question
21-08-2007 9:40 AM
You have the right info but you can increase the download/upload allowance by pre-paying at the rate of 75p per additional 1 gig or allowing your monthly use to go above 1Gb and paying £1 per extra gig afterwards. You can also set a limit on how much you will allow to be spent each month. For VPN you really need BBYW2
Message 2 of 5
(620 Views)
21-08-2007 9:44 AM
BBYW option 1 has 1GB of usage between 8am-Midnight included, you can add extra for 75 pence pre GB in advance or £1 per GB as you need it. VPN is rate limited to 128Kbps, you may wish to go for option 2 if you are going to need more than this speed for VPN.
Message 3 of 5
(620 Views)
17-04-2008 11:14 PM
Quote from: Chris BBYW option 1 has 1GB of usage between 8am-Midnight included, you can add extra for 75 pence pre GB in advance or £1 per GB as you need it. VPN is rate limited to 128Kbps, you may wish to go for option 2 if you are going to need more than this speed for VPN.
I know this is an old post so if i went accidently over on my broadband (option 1) i would be charged £1. Microsoft download a huge 170mb update making me VERY close to the limt.
Thank you for your replies.
Message 4 of 5
(620 Views)
17-04-2008 11:41 PM
Only if you've set the PAYG option by ticking the box on this page, otherwise you'll be rate limited to 128kbps until your next billing date.
Message 5 of 5
(620 Views)
