BBC DNS fubar / BBC vanishes from the net
- Re: BBC DNS fubar / BBC vanishes from the net
29-03-2011 11:08 PM
29-03-2011 11:10 PM
EDIT - added post URL
29-03-2011 11:10 PM
29-03-2011 11:11 PM
Looks like someone has either wiped all the DNS records (unlikely as they would be cached somewhere) or the BBC DNS servers have all failed (or a key bit of kit linking them to the net has).
Single point of failure comes to mind.... unless Anon are at it again!
29-03-2011 11:12 PM
29-03-2011 11:14 PM
much more accurate than the BBC one.
29-03-2011 11:16 PM
29-03-2011 11:16 PM
If thats a failure, it would indicate much higher level DNS failure, which I very much doubt.
My suspects are catastrophic human error, or some form of cyber attack. I will keep digging though, some of the errors I've had back are extremely strange, indicating DNS servers giving bad responses.
29-03-2011 11:21 PM
BUT still doesn't work.
29-03-2011 11:21 PM
29-03-2011 11:24 PM
29-03-2011 11:24 PM
The BBC has a massive number of IP addresses, and I suspect many of their internal systems expect to be able to talk to each other by web address, which with no name servers means that even internally to the BBC right now, their websites are down, it may be a day or two for the BBC to pick up and restore all of its services even after fixing this "DNS" issue.
Quote from: walker23 Found it (I think): 212.58.239.25
29-03-2011 11:27 PM
Think Egypt a few weeks back, except I doubt this is some government conspiracy to try and suppress the masses.
The only IP block that the BBC is announcing at the moment is 132.185.144.0/20, which doesn't contain any of the BBC.co.uk DNS servers
29-03-2011 11:28 PM
Analogue is due to switch off in our region tonight, mybe someone pulled the wrong plug?
29-03-2011 11:29 PM
