Awaiting Activation but Phone is now Playing Up - Rings Once Help...
- Awaiting Activation but Phone is now Playing Up - ...
13-02-2011 7:24 PM
I am posting this on behalf of my friend who is awaiting activation on the 15th for the Broadband only package.
Since they ordered it they are now having problems with the phone which they have with BT. The phone will ring once for a very short time then cut off with the caller at the other end actually paying for the call even though they can't speak to them!!
They can ring out no problem and the phone was fine before they signed up to Plusnet broadband.
Any ideas?
Thanks.
Re: Awaiting Activation but Phone is now Playing Up - Rings Once Help...
13-02-2011 8:08 PM
13-02-2011 8:57 PM
Why is it now a BT line fault? it was working fine before they ordered broadband from plusnet, just seems odd to me.
Should they hide there ADSL bits when they report it as well!?
dick:quote
13-02-2011 9:21 PM
13-02-2011 9:33 PM
I shall tell them to get BT out then, do they need to hide/don't mention their ADSL equipment though as Jaggies says?
dick:quote
13-02-2011 9:35 PM
Edit, If BT ask If you have broadband just tell them you don't have any, Because you don't at the moment.
13-02-2011 9:48 PM
Cheers.
dick:quote
13-02-2011 9:54 PM
Best of luck and feel free to post back with any further problems, We will be happy to help.
13-02-2011 9:56 PM
Whilst I acknowledge that there is an obvious view that the broadband order may be the cause, there is no evidence of this. It could be the cause, but equally not.
Despite this, even we knew evidentially it was the cause, there is nothing Plusnet, or any other broadband provider can do about this. Phone faults must be reported to the phone provider.
A little reverse example. If BT were to replace the telegraph pole serving the property and suddenly broadband was to have problems, but the line was as clean as a bell. You wouldn't report this to BT, instead you report it to the broadband provider.
The one exception to all this is that voice faults are always the primary fault. If you lose or have problems with both broadband and voice, even if the broadband problems are more severe that the voice, the voice fault should always be reported first. The majority of repairs to voice will repair the broadband too, though that isn't to say that broadband may need to minor follow-up work.
14-02-2011 3:26 PM
They are calling BT about it, just hope they don't have to ring them back!
Thanks for the welcome chaps
