Authentication failed
- Authentication failed
25-11-2012 10:28 PM
I've just done a factory reset of my router but now trying to reconnect I'm getting the Authentication failed message. I'm using the username and password suggested in the FAQs unsuccessfully. Any help appreciated
Message 1 of 6
(2,238 Views)
5 REPLIES 5
Re: Authentication failed
25-11-2012 10:37 PM
It is possible that a factory reset takes it back to the Technicolor defaults which are username is Adminstrator (case sensitive - make sure you have a capital A), and the password left blank.
Message 2 of 6
(1,383 Views)
25-11-2012 10:39 PM
For internet access you need to use the credentials below:
username@plusdsl.net
password
In case of doubt validate your user name and password by logging on to your account vis the Plusnet web site.
password
Message 3 of 6
(1,383 Views)
25-11-2012 11:30 PM
Unfortunately neither suggestion has worked but thanks for trying.
Message 4 of 6
(1,383 Views)
25-11-2012 11:48 PM
You could alway try using the serial number of the router for the password
Also since you have done a reset use the name and passord that came on the card that came with the router
Hope one of those works for you
Edit - Sorry just gone back over it thought u logging into router but it is the connection that is the problem which should be your username@plusdsl.net and your account password as already mentioned and case sensitive.
Message 5 of 6
(1,383 Views)
26-11-2012 10:14 AM
I see you got back on not long after midnight, I assume everything's ok for you now?
Message 6 of 6
(1,383 Views)
