Authentication Fault
nodrogs
Hi, wondering if anyone can help.  I'm trying to login to plusnet for the first time but I keep getting an authentical failure on my router.  I'm using the correct login details (username@plusdsl.net) and password.  Tried changing filters etc.  Router previously worked with plusnet before I moved house.  I have a solid ADSL light but no internet light on the router.
Thanks for any help!
Stephen
8 REPLIES 8
Fixes: 160
Re: Authentication Fault
Hi Stephen,
Welcome to the forums.
Just to be clear, am I correct in concluding that you have just moved your service from one property to a new one and you have never before connected to the PlusNET service at the new address?
With the title given, in the current circumstance of the weekend's major outage, there is a risk that this thread might be associated with that issue and you might be advised that you need to power down the router and wait.
It is more than likely that the account has not yet been activated on / associated with the new line.
Hopefully this is something which CRT (PlusNET staff) will address in a jiffy!
Kevin
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Hi and welcome to the forums,
Although your account is active, the broadband potion hadn't been enabled.
I've sorted this now and you should be able to connect. I'm just looking into why you had the problem in the first place.
Tony
 Tony T
nodrogs
Thanks Tony, I'll check it tonight and see what happens.
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
You've got an ongoing connection now.
Tony
 Tony T
w23
Fixes: 4
Quote from: plusnettony
I've often suspected that the internet involved a bit of magic but never previously realised that witchcraft was involved.  Cheesy
Call me 'w23'
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Quote from: w23
I blame my faulty keyboard.  Wink
Tony
 Tony T
nodrogs
Hi Tony, all up and running now, thanks for your help!
Stephen
adamwalker
Fixes: 221
Thanks a lot for letting us know Stephen and kudos to Tony!  Grin
 Adam Walker
