Attenuation has increased with different router
Fixes: 389
I've had to replace my DG834G v3 router as there was an intermittent wireless problem (it would lose wireless connectivity and only a soft or hard reset would fix it).
I managed to get a v5 from Ebay which, after a few problems trying to connect (would sync but not connect) all seems OK except that the attenuation has jumped from 46 to 50. I have previously used two other Thompsons as supplied by PN and the attenuation has always been 46.
I have installed the latest firmware (V1.6.01.34).
Stats below.
Can anyone suggest a possible reason why the attenuation should increase and whether that is indicative of a possible issue/problem.
Thanks.
Forum Moderator and Customer
3 REPLIES 3
Re: Attenuation has increased with different router
Quote from: Mav
Yes, put simply different routers measure it in different ways.  Cool
As you may know ADSL uses a very wide band of frequencies (tones) and the attenuation is different for each.
It purely depends what and where the router measures and whether, for example it takes a "middle" or typical tone or averages and if so over what.
Fixes: 389
Thanks HPsauce.
So, based on what you're saying do I assume that, because it has been calculated differently, I will sync lower due to the higher attenuation or is the sync rate adjusted somehow to compensate for the difference in the way it's been calculated?
In other words, would I be better off sourcing another v3 DG834G or stick with what I have now?
Bear in mind that it has been stable for some time at around the 5500 mark.
No, none of that. It's just an "after the fact" calculation, doesn't affect anything.
