Attenuation has increased with different router
- Re: Attenuation has increased with different route...
09-04-2011 12:59 PM
I've had to replace my DG834G v3 router as there was an intermittent wireless problem (it would lose wireless connectivity and only a soft or hard reset would fix it).
I managed to get a v5 from Ebay which, after a few problems trying to connect (would sync but not connect) all seems OK except that the attenuation has jumped from 46 to 50. I have previously used two other Thompsons as supplied by PN and the attenuation has always been 46.
I have installed the latest firmware (V1.6.01.34).
Stats below.
Can anyone suggest a possible reason why the attenuation should increase and whether that is indicative of a possible issue/problem.
Thanks.
Stats below.
Thanks.
Forum Moderator and Customer
Message 1 of 4
(771 Views)
3 REPLIES 3
Re: Attenuation has increased with different router
09-04-2011 1:28 PM
Quote from: Mav Can anyone suggest a possible reason
Yes, put simply different routers measure it in different ways.
As you may know ADSL uses a very wide band of frequencies (tones) and the attenuation is different for each.
It purely depends what and where the router measures and whether, for example it takes a "middle" or typical tone or averages and if so over what.
Message 2 of 4
(416 Views)
09-04-2011 1:37 PM
Thanks HPsauce.
So, based on what you're saying do I assume that, because it has been calculated differently, I will sync lower due to the higher attenuation or is the sync rate adjusted somehow to compensate for the difference in the way it's been calculated?
In other words, would I be better off sourcing another v3 DG834G or stick with what I have now?
Bear in mind that it has been stable for some time at around the 5500 mark.
Message 3 of 4
(416 Views)
09-04-2011 2:04 PM
No, none of that. It's just an "after the fact" calculation, doesn't affect anything.
Message 4 of 4
(416 Views)
