Asus Rt n56u
- Re: Asus Rt n56u
Asus Rt n56u
19-08-2013 10:35 PM
Hi all, im due to get this router Fri., currently using PN supplied router, but find range on wi-fi is not great, although router is ok, anyway i need to know as i have fibre connection is it best to power down router using router web page, and then switching off, do i then need to turn of BT modem, and if so for how long, or is it as easu as just turning router (PN) off, and swapping over leaving modem turned on, thanks
Message 1 of 2
(710 Views)
1 REPLY 1
Re: Asus Rt n56u
19-08-2013 11:51 PM
I bought a RT-N66U, just clicked disconnect on the Plusnet modem and left BT modem intact, configured all the settings on the Asus before swapping it out to avoid having to reboot etc. Worked fine.
Message 2 of 2
(423 Views)
