Asus RT-N10E N150
JustJoe
Asus RT-N10E N150
Hi guys
Getting fibre installed this Thursday I have the router above, brand new never used.  Would it be a better option than the Plusnet router?
Cheers.
2 REPLIES 2
bill888
Champion
Fixes: 38
Re: Asus RT-N10E N150
deleted
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
Fixes: 392
Well it should work with Fibre but whether it's a better option I don't really know. Given that it has an external aerial its wireless performance may be better ( the PlusNet TG582n can be poor in some circumstances ).
I can't find any information about its throughput capabilities and since it's quite a cheap router it may not be quite up to handling Fibre connection especially if your speed is likely to be up towards the 80Mb.
Best option is to suck it and see I'm afraid.
