Asus N66U Users Thread
- Asus N66U Users Thread
- « Previous
- Next »
Re: Asus N66U Users Thread
20-06-2014 6:03 PM
Anyone able to help me with the following please? I have an ASUS DSL-N66U but I'm having issues getting it working stable on my Plusnet FTTC install. Any other DSL-N66U users able to post screenshots of their config or a step-by-step of what you configured for either direct on the DSL port using the device as a VDSL modem/router or if you've had any luck getting the DSL-N66U configured successfully leaving the BT Modem in place and connecting via the WAN port? (Currently on the stock ASUS firmware, latest once available).
If I use the VDSL capabilities of the N66U I see much better upload speeds than the supplied BT Modem (18mb vs the 14mb I get otherwise) but I seem to lose the connection a lot.
Tried setting up via the WAN and leaving the modem in place and I just cannot get it to connect this way (the WAN icon indicates cannot get a response from the remote server). (Would be happy leaving the BT Modem in place even with the lower upload speed just for the better wi-fi and features, otherwise this device is just an expensive doorstop!)
TIA
PS: I've attached a screenie of the line stats from when it was on the DSL port in case anyone sees anything interesting that might indicate why a lot of disconnects (not sure noise margins I should be looking for on FTTC).
20-06-2014 8:11 PM
28-06-2014 12:19 PM
30-06-2014 10:05 PM
2014.06.27 update ASUS RT-N66U Firmware Version 3.0.0.4.376.1071
01-07-2014 10:15 AM
Downloading now
26-07-2014 10:53 AM
26-07-2014 11:01 AM
Are you considering buying it?
26-07-2014 11:38 AM
Wired I get around 34 Mb/s , wireless on ground floor of my 100 year old house,with brick walls its around 13 Mb/s.
Outside on a deck area 3-6 Mb/s I use it here to watch Sky Go which is OK most of the time but I do get some buffering.
As we are nearing autumn I wont be using wifi outside too much.
If I do go for the Asus a tidy installation will be required (my wife insists)
26-07-2014 12:20 PM
Asus are in the process of having a bit of a revamp of their routers and router firmware.
The other option would be the DSL-xx range (it's a router/modem in one) that supports VDSL2 - this would mean you would not need the Openreach modem.
Edit: This one - http://www.asus.com/uk/Networking/DSLAC68U/ but I am not sure on the cost (is around $200 in the US).
26-07-2014 12:26 PM
24-11-2014 9:48 AM
Router seams to be holding upto its job, it offers standard 2,4ghz wireless and 5ghz... ive tried the 5ghz and don't see much difference so ive reverted back too default 2.4. Apart from that this router I have no issues with
Above is my wired connection, my wireless gives me 50 meg down and 17 up.
07-01-2015 1:25 PM
Let's see if that solves my daily disconnections. Modem to PN up for 10 days solid but I kept losing connections about 3 or 4 times a day for about 30 secs a go.
16-06-2015 5:49 AM
Up till this week, according to android wifi analyser, I was alone on the 5g spectrum. One of my neighbours has now got a BT Homehub and I can see him on channel 36. The Asus has now moved me to 48.
His signal is rock solid at a constant 30db, through a party wall, whilst my Asus fluctuates from 30 to 70 and when it hits 70 I lose my tablet connection which is only about 8 feet away with all 3 aerials in line of sight and set at the 45/0/45 as recommended.
Also on the latest firmware.
Who makes the homehub as it does seem to be a good unit and worth considering.
03-10-2015 11:07 PM
Any ideas? Thanks
04-10-2015 10:23 AM
Hi - Are you on ADSL connection?
Are you aware that unlike the 582N which is a combined Router/modem that the RT N66u is ONLY a Router and needs a Modem to connect.
- « Previous
- Next »
