Assigned a non-plusnet IP address
- Assigned a non-plusnet IP address
Re: Assigned a non-plusnet IP address
31-01-2014 3:44 PM
So you have the correct telephone number, a working phone line and broadband but it all appears to be with another provider who isn't billing you (i.e. TalkTalk) !
Have you *ever* had any dealings with TalkTalk ?
31-01-2014 3:49 PM
dick:quote
31-01-2014 4:02 PM
31-01-2014 4:27 PM
31-01-2014 4:31 PM
In the router interface click disconnect and then connect. Now go to Event Logs under Technicolor Gateway. You should have entries that look like this (but I bet you haven't):
Quote Jan 31 16:26:42 PPP CHAP Receive success (Internet)
Info Jan 31 16:26:42 PPP CHAP Receive challenge from rhost PTW-AG01 (Internet)
Info Jan 31 16:26:41 PPP CHAP Receive challenge from rhost ERX15.Miltonkeynes2 (Internet)
Info Jan 31 16:26:34 FIREWALL event (1 of 33): modified rules
Info Jan 31 16:26:34 FIREWALL event (1 of 50): created rules
Warning Jan 31 16:26:34 PPP link down (Internet) [81.174.168.15]
What you do have might be informative and might be something you could show to the next engineer.
31-01-2014 5:44 PM
Quote from: Matt Hi, the fault's come back to us and is immediately requesting another engineer visit. I suspect therefore it's still jumpered incorrectly at the exchange if you're still showing as being on talktalk, as they've requested another engineer - I'd imagine the config has already been checked if that's the case.
Many years ago, I had a customer with similar problems, although it was just a report of login trouble. It took 3 or 4 visits to get to the bottom of it.
His line had the correct phone number, & the correct ADSL port, connected to it.
This was in the days before Openreach, when we contacted BT Wholesale direct. The BTW guy could drop sync on the modem, etc. proving correct port, so the ADSL virtual path was rebuilt, but same problem remained.
He got me to set the login to @(BTW guys name) & then did a search for the port that tried to login with that name.
Low & behold, it was to port of a customer 100 metres down the road. I went to see this customer & he was having login trouble too.
Things were OK at the exchange MDF, but failed at the cab. The problem was perfect crosstalk on the ADSL frequencies but not on Audio frequencies.
Problem cleared by E side change.
It most likely won't help in this case, but it's worth thinking about.
Nick
31-01-2014 6:03 PM
Quote from: jelv If you are using the Plusnet supplied TG582 could you do the following please:
Here's my log from disconnect to connect:
Jan 31 17:58:34 FIREWALL event (1 of 1): deleted rules
Warning Jan 31 17:58:34 PPP link up (Internet) [2.96.84.218]
Info Jan 31 17:58:34 PPP CHAP Chap receive success : authentication ok
Info Jan 31 17:58:34 PPP CHAP Receive challenge (rhost = npe001.bri)
Info Jan 31 17:58:25 FIREWALL event (1 of 1): modified rules
Info Jan 31 17:58:25 FIREWALL event (1 of 1): created rules
Warning Jan 31 17:58:25 PPP link down (Internet) [2.99.227.114]
31-01-2014 6:49 PM
31-01-2014 6:52 PM
01-02-2014 11:59 AM
01-02-2014 5:51 PM
02-02-2014 11:52 AM
I would have said call Talktalk but if they don't have an account for you then that probably won't get you anywhere as they won't recognise you as a customer
02-02-2014 4:01 PM
02-02-2014 5:56 PM
14-02-2014 2:22 PM
