Assigned a non-plusnet IP address
picbits
Re: Assigned a non-plusnet IP address
How incredibly strange !
So you have the correct telephone number, a working phone line and broadband but it all appears to be with another provider who isn't billing you (i.e. TalkTalk) !
Have you *ever* had any dealings with TalkTalk ?
AGil83
I did an online thingy to see what service I could get from them when I was looking to switch provider last year, before I chose plusnet, but that's it.
dick:quote
AGil83
Also, don't know if this has any bearing but my current line speed in the member centre is showing 21.5 Mb but I've never been able to get more than a speed of 3 Mb from home. Is this showing the sync speed from the engineer's test at the exchange? If it is, would that suggest he was also unable to register a connection from the premises?
orbrey
Hi, the fault's come back to us and is immediately requesting another engineer visit. I suspect therefore it's still jumpered incorrectly at the exchange if you're still showing as being on talktalk, as they've requested another engineer - I'd imagine the config has already been checked if that's the case.
jelv
Fixes: 10
If you are using the Plusnet supplied TG582 could you do the following please:
In the router interface click disconnect and then connect. Now go to Event Logs under Technicolor Gateway. You should have entries that look like this (but I bet you haven't):
Jan 31 16:26:42 PPP CHAP Receive success (Internet)
Info Jan 31 16:26:42 PPP CHAP Receive challenge from rhost PTW-AG01 (Internet)
Info Jan 31 16:26:41 PPP CHAP Receive challenge from rhost ERX15.Miltonkeynes2 (Internet)
Info Jan 31 16:26:34 FIREWALL event (1 of 33): modified rules
Info Jan 31 16:26:34 FIREWALL event (1 of 50): created rules
Warning Jan 31 16:26:34 PPP link down (Internet) [81.174.168.15]
What you do have might be informative and might be something you could show to the next engineer.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Madman
Quote from: Matt
Many years ago, I had a customer with similar problems, although it was just a report of login trouble. It took 3 or 4 visits to get to the bottom of it.
His line had the correct phone number, & the correct ADSL port, connected to it.
This was in the days before Openreach, when we contacted BT Wholesale direct. The BTW guy could drop sync on the modem, etc. proving correct port, so the ADSL virtual path was rebuilt, but same problem remained.
He got me to set the login to @(BTW guys name) & then did a search for the port that tried to login with that name.
Low & behold, it was to port of a customer 100 metres down the road. I went to see this customer & he was having login trouble too.
Things were OK at the exchange MDF, but failed at the cab. The problem was perfect crosstalk on the ADSL frequencies but not on Audio frequencies.
Problem cleared by E side change.
It most likely won't help in this case, but it's worth thinking about.
Nick
AGil83
Quote from: jelv
Here's my log from disconnect to connect:
Jan 31 17:58:34 FIREWALL event (1 of 1): deleted rules
Warning Jan 31 17:58:34 PPP link up (Internet) [2.96.84.218]
Info Jan 31 17:58:34 PPP CHAP Chap receive success : authentication ok
Info Jan 31 17:58:34 PPP CHAP Receive challenge (rhost = npe001.bri)
Info Jan 31 17:58:25 FIREWALL event (1 of 1): modified rules
Info Jan 31 17:58:25 FIREWALL event (1 of 1): created rules
Warning Jan 31 17:58:25 PPP link down (Internet) [2.99.227.114]
jelv
Fixes: 10
Guess what name crops up repeatedly if you Google npe001.bri? Absolute conclusively proves who your line is wired to!
jelv
Fixes: 10
Just thought of something else; which exchange are you on?
AGil83
jelv
Fixes: 10
Thanks - that thought ruled out!
dragon2611
Hope Plusnet can get an engineer out to check/fix the jumpering.
I would have said call Talktalk but if they don't have an account for you then that probably won't get you anywhere as they won't recognise you as a customer
picbits
Calling TalkTalk when you *are* a customer used to be a rather distressing experience. I dread to think what would happen if you were trying to explain to a foreign call centre operative that you had a jumpering fault at the exchange.
Strat
Fixes: 562
Probably would suggest the Returns Department at Marks & Spencer Wink
Customer and Forum Moderator. Windows 10 Firefox 100.0.1 (64-bit (64-bit)
picbits
This one has been bugging me a bit - did you get sorted in the end ?
