Are wide variations in fibre speed normal ?
- Are wide variations in fibre speed normal ?
14-05-2013 8:04 PM
Lots of tests show download speeds in the low 30 Mbs. with pings in the 30s. However repeating the test a few minutes later often gives download speeds more in keeping with expectation, ie. between high fifties and sixties sometimes giving 70 plus Mbps.
My Bt ip profile is currently 77.44 Mbps and has remained constant since the first week. Upload is pretty stable between 14 to 17 Mbs. Does any one have similar experiences and is this normal for FTTC ? ( BTW the cabinet is only about 100 metres away.)
Mike (edgeways)
Re: Are wide variations in fibre speed normal ?
14-05-2013 9:16 PM
Mine was mid April and whilst my ip profile is lisp 77.44 it does vary quite a bit. Worse results at peak times with best results in the morning or before approximately 5pm
15-05-2013 1:41 AM
15-05-2013 9:05 AM
15-05-2013 11:53 AM
Are you connected via a wired or wireless connection when performing the speed tests?
15-05-2013 1:28 PM
i hit 73Mb on speedtest.net and sometimes at peak times it will drop to 68/69 Mb.
16-05-2013 11:21 AM
Re the query from Chris, I am using a wired Ethernet connection when carrying out speed tests.
Interesting that this morning I have done a couple of tests both giving 73 Mbps plus .
Does that seem to indicate that the connection is quite healthy and that the slow speeds are possibly due to some sort of congestion ?
I will continue to monitor speeds for a few days and report .
Thanks, regards.
Mike (edgeways)
16-05-2013 1:31 PM
16-05-2013 4:18 PM
25-05-2013 10:04 AM
The problem seems to have been fixed without referring to support. Speed tests have now become very consistent at around the expected 70 Mbps.
I have no idea where the fix has come from, maybe the exchange? Nevertheless now a happy bunny again.
Thanks for help and advice.
Mike (edgeways)
