Are we stuck?
- Re: Are we stuck?
Are we stuck?
23-03-2013 3:23 PM
Just a general broadband techie question before I think of raising it with PN in the BB forum..
Our upstream is
This obviously varies from day to day but I was wondering if its possible to get a faster upload speed somehow without major hardware changes and expense? - EG is there some magic settings that can be tinkered with at the ISP or home users end?
Our upstream is
Message 1 of 9
(1,543 Views)
8 REPLIES 8
Re: Are we stuck?
23-03-2013 3:24 PM
Raise a ticket asking for the upload to be uncapped
Message 2 of 9
(875 Views)
Re: Are we stuck?
23-03-2013 3:32 PM
Just be aware uncapping the upload speed can lower your download speed and trigger connections issues. Every time I have had a unwanted uncapping, my connection has become unstable.
FTTP 500 regrade from Tues 28th November
Message 3 of 9
(875 Views)
Re: Are we stuck?
23-03-2013 3:36 PM
What causes that then? Is it just the sheer amount of data going both ways?
Reason I'm asking is that I may need to start sending large amounts of data to an external server soon and I'm just wondering if our normal BB connection would in theory be able to handle it?
Message 4 of 9
(875 Views)
Re: Are we stuck?
23-03-2013 3:43 PM
This happens very rarely - it happened to me - and the change can be reversed very easily if it does
The problem is usually down to pushing the noise margin on upstream to 6dB can cause instability which is seen by the downstream DLM which can then increase the downstream noise margin
It is still worth a try
Message 5 of 9
(875 Views)
Re: Are we stuck?
23-03-2013 3:49 PM
Ok, thanks guys, I will raise a ticket
Any idea what sort of speeds it will go to though? - Presumably about 1M would be good with us..
Message 6 of 9
(875 Views)
Re: Are we stuck?
23-03-2013 4:00 PM
Should be about that - moved to Broadband section
Message 7 of 9
(875 Views)
Re: Are we stuck?
25-03-2013 11:51 AM
Hi Sprite,
A modify order has been placed to uncap your upload and this will complete tomorrow.
I've also dropped a ticket on your regarding this.
Chris
Chris
Message 8 of 9
(875 Views)
Re: Are we stuck?
25-03-2013 3:43 PM
Hi Chris
Thanks very much for being super helpful - especially as I'd completely forgotten about raising the ticket!
Sprite
Sprite
Message 9 of 9
(875 Views)
