Are PN throttling Streaming software?
- Are PN throttling Streaming software?
03-03-2009 9:14 PM
Tonight I have tried to connect to various streaming software and other sites only to find that I cannot connect to any of them
I haven't been able to use http://pages.tvunetworks.com/downloads/player.html# for well over a year despite the channels on there being perfectly legal.
http://tvants.en.softonic.com/ is another piece of software that is unusable, none of the channels connect
Tonight I can't even access Sopcast as on every channel im getting 'cannot retrieve data' or 'connecting'. It uses P2P yet is streaming.
Yet other people are having no such problems accessing these services, are you throtting or blacklisting these services?
It's not a problem with my router as I have rebooted several times, have also tried on a modem and even dropped the firewall. Sopcast is occasionally usuable but often unaccessible, although it was fine at the weekend, but TVAnts and TVU are never ever accessible, and tonight also I have been unable to use Veetle. Tvcatchup is fine though.
I would rather know if you throttling or blacklisting software so that I can choose another ISP which best suits my requirements.
Message 1 of 7
(2,109 Views)
6 REPLIES 6
Re: Are PN throttling Streaming software?
03-03-2009 9:19 PM
Hiya,
We actually prioritise streaming traffic to make sure that things like P2P and Usenet don't drag it down.
If you use Wireshark you can see exactly how we're prioritising your streaming sites.
There's a link showing to how to check here:
http://www.plus.net/support/broadband/troubleshooting/wireshark_video.shtml
Message 2 of 7
(676 Views)
03-03-2009 9:53 PM
Hi James
I've just run that packet capture program on TVU and is seems that it isn't being classed at all due to the 0x00 value
Differentiated Services Field: 0x00 (DSCP 0x00: Default; ECN: 0x00)
I'll run the software on other software I can't use. Should I then post the results in a ticket?
Message 3 of 7
(676 Views)
03-03-2009 10:05 PM
Are you sure you're checking the *inbound* packets and not the outbound ones?
Message 4 of 7
(676 Views)
03-03-2009 10:22 PM
I just checked that it was my IP again and I can now see Differentiated Services Field: 0xa0 (DSCP 0x28: Class Selector 5; ECN: 0x00) that's for TVU
As soon as it hit 10pm Sopcast started working again and the stream is fine, shame that the game is over now though
I'll run a test on TVAnts but it never works so I suspect it's unclassified.
[Moderator's note by Adie (Adiewoo): Full quote of preceding post removed, as per Forum Rules ]
Message 5 of 7
(676 Views)
03-03-2009 10:58 PM
I'll throw this in just in case there's a connection: I recently had problems with poor performance on iTunes, which were eventually found to be caused by a problem in the traffic management profile PN had set for between 9-10pm. The fact you say Sopcast starts working again at 10pm makes me wonder if perhaps the error affecting iTunes wasn't the only one...
Message 6 of 7
(676 Views)
04-03-2009 12:10 AM
You could well be right, the problems I was having with Sopcast were from when I tried from 8-10 pm
I ran some more tests with Wireshark
Sopcast
Differentiated Services Field: 0x40 (DSCP 0x10: Class Selector 2; ECN: 0x00)
It will connect but it looks like the priority is Silver even at off-peak
TVU
Getting a mixture of
Differentiated Services Field: 0x80 (DSCP 0x20: Class Selector 4; ECN: 0x00)
It never connects to any channels on TVU, it used to a while back, and the one I tried with the above data is running a stream of 389 kb/s
Sopcast
TVU
Message 7 of 7
(676 Views)
