Are 2 routers possible
- Re: Are 2 routers possible
12-07-2012 7:35 AM
Hello
My router is positioned in my study(which is an upstairs bedroom ) next to my desk top
I use a lap top in the downstairs rooms and in the conservatory.
The signal is poor.
Downstairs I have telephone sockets.
Is it possible to have an extra router plugged into a down stairs phone socket?
Thank you
diabeg
The signal is poor.
Thank you
diabeg
Message 1 of 7
(1,408 Views)
6 REPLIES 6
12-07-2012 7:55 AM
No unless the telephone line is separate one.
Why not consider homeplugs lots of choice I use these.
http://preview.tinyurl.com/7qraemn
Message 2 of 7
(803 Views)
12-07-2012 8:28 AM
I havent used these but I thought they had to be on the same circuit. I have separate fuses for uppstairs and downstairs so assumed that if my router was upstairs and my client was downstairstheis would not work.
On the otherhand I wouldn't be surprised if i got that totally wrong.
Message 3 of 7
(803 Views)
12-07-2012 9:19 AM
I use http://www.amazon.co.uk/TP-Link-TL-PA211KIT-200Mbps-Powerline-Ethernet/dp/B004INVKP4
Before I moved house I had them on separate ring mains (main house and extension from the same meter but on different fuse boxes) and they were fine.
Message 4 of 7
(803 Views)
12-07-2012 9:41 AM
These seem awesome:
http://www.amazon.co.uk/TL-WPA281KIT-Powerline-Extender-Wireless-Starter/dp/B0067GS29W/ref=sr_1_2?ie...
Plug in the non-wifi one upstairs, and then the wifi one downstairs. As far as I know, set it up right as an access point and it extends the range AND gives you a ethernet out incase its needed.
Message 5 of 7
(803 Views)
12-07-2012 9:45 AM
and these do everything and are very cheap http://www.solwise.co.uk/net-powerline-plv-500av-pe.html found about them from http://forums.thinkbroadband.com/dslrouter/f/4138358-solwise-value-500-homeplugs.html
Message 6 of 7
(803 Views)
12-07-2012 3:11 PM
Thank you all for your replies I will consider all the products that you have suggested and I am certain the matter will be resolved
Thank you very much
diabeg
Thank you very much
diabeg
Message 7 of 7
(803 Views)
