Apple TV won't airplay or share
- Re: Apple TV won't airplay or share
13-08-2012 8:24 PM
I just got an Apple TV, and while it's connected fine to the network (i.e. I can watch YouTube etc) It can't see my iTunes library on my computer and my iPhone doesn't have the option to AirPlay.
Any ideas? It's driving me crazy. I have a Thompson router.
Message 1 of 6
(1,847 Views)
5 REPLIES 5
13-08-2012 9:13 PM
You will need to set up sharing for your iTunes library on your computer (in iTunes preferences, if I remember right).
Are you saying that you can't find the Airplay symbol on your iPhone or is your Apple Tv not showing on the Aiplay pop up menu?
Message 2 of 6
(763 Views)
14-08-2012 1:17 PM
Yeah, I'd done all that. Turns out resetting the router fixed it.
Message 3 of 6
(762 Views)
16-08-2012 11:57 AM
Kept having to reset the router every time it was unused for a while.
Ended up changing the security to WEP and touch wood everything has been fine since.
Message 4 of 6
(762 Views)
17-08-2012 9:58 AM
Quote Kept having to reset the router every time it was unused for a while.
That doesn't sound right to me, glad to hear you've nailed it but for now but let me know if that presents itself as a problem again.
Message 5 of 6
(762 Views)
17-08-2012 10:45 AM
Was your Iphone connected to the same router ok? sometimes when it goes to lock screen it disconnects. When you unlock it reconnection should be automatic but can sometimes delay. I use it allot and dont normally have an issue.
Message 6 of 6
(762 Views)
