Appalling speed and customer service
- Appalling speed and customer service
Re: Appalling speed and customer service
11-12-2014 9:48 AM
Thanks for posting. I’ve checked the account for you and everything does appear to have been done correctly from our side. As others have posted, we need to sort the phone fault out first and the symptoms described suggested this was a problems. I would expect that any engineer to be sent would resolve the issue he was there for.
Weekend visits depend on your area and engineer availability. Just because the engineer is working that weekend doesn’t mean that we have the opportunity to book him. We will always try to book the most suitable engineer visit for you, but this could be limited to week days in certain area and circumstances.
The Email sent is totally automated and we didn’t know that anything needed to be done. This may be something that we can change in the future, but it won’t been done any time soon. In the near future, we would expect customers to tell us if the speeds are slow.
Email isn’t an accountable or secure form of communication so we don’t use it for support requests. I’ve been using the contact us/help and support assistant since we introduced it, and it is a great improvement over Email for both customers, staff answering tickets, and management obtaining information and stats.
We see no reason why an engineer shouldn’t visit you once it’s been booked. If there are problems though, we’ll deal with them once they’ve happened.
I hope this provides a little insight into matters.
11-12-2014 10:13 AM
Quote from: Anotherone Did the OR engineer plug any test equipment in to your NTE5 and carry out ant tests, or did he just listen on the phone?
Broadband noise on the line can be caused by iffy joints and this is smelling more like buck passing by the minute!
He called into the line to check before he arrived.
Once at the property, he unplugged my leads, changed the filter, plugged in his equipment, did a further call from his mobile to the line to get some sort of report on his screen, then called Plusnet to tell them the line wasn't the issue, then was there another 15 mins or so of fiddling and left.
From my interactions with Plusnet and the engineer, I'm on his side at the moment.
11-12-2014 10:20 AM
Basically as stated here http://community.plus.net/forum/index.php/topic,96155.0.html we need the stats from the router, the IP profile from the BT speed test and the Plusnet Current Line Speed
11-12-2014 10:29 AM
jim:quote
11-12-2014 10:34 AM
11-12-2014 10:37 AM
jim:quote
11-12-2014 10:41 AM
Second
Regardless of what the engineer said it isn't a Plusnet fault unless the router they provided is duff as they can't influence the sync with the exchange
Have you tried a different router and did the engineer report what the sync speed actually was
11-12-2014 10:49 AM
Engineer didnt say it was Plusnet's fault, he said broadband traffic was causing the issue.
The main complaint at present with Plusnet is them claiming I reported a line fault when I reported a broadband fault, and them still claiming I did no such thing "according to their notes". Well perhaps seeing as they say they record calls, listen to the call and what I was phoning to report, rather than an incorrect written record of what the CS rep entered on the system.
Plus, I said I wanted the broadband issue checked there and then, it was Plusnet who insisted on re-booking a subsequent call-out, the O.R. engineer would have worked there and then if they'd ok'd it.
11-12-2014 10:55 AM
PS Quoting an immediately preceding post is unnecessary, as it's the one just before it's easy to follow. When it's something several posts back,or a part post quote (sometimes makes something clearer), that makes sense
11-12-2014 11:04 AM
This is on the support ticket
xDSL Status Test Summary
Sync Status: Circuit Not In Sync
General Information
NTE Status: NTE Power Status: Unknown Bypass Status:
Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 0.0 0.0
SNR Margin: 0.0 0.0
Errored Seconds: 0 0
HEC Errors: 0
Cell Count: 0 0
Speed: 0 0
Maximum Stable Rate (KBPS): 576 Fault Threshold Rate (KBPS): 576
Mean Time Between Retrains (Seconds): 3 Mean Time Between Errors Upstream (Seconds): 333
Indicative Line Quality: R Mean Time Between Errors Downstream (Seconds): 231
Custom Thresholds
MTBR_RED: MTBE_RED:
MTBR_GREEN: MTBE_GREEN:
11-12-2014 12:03 PM
What sort of Master Socket do you have, is it like the one on the left? Does it have Filtered Faceplate like one of these, if so which one?
Can you hear/have you heard any crackling or other noises on the line when using the phone? Have you had any problems with incoming or outgoing calls? eg. Does the phone ring and stop before you answer, but the caller is still there when you pick up?
11-12-2014 12:11 PM
Your second hyperlink doesn't work.
The phone was only added to the line on Saturday as I didn't intend having one originally, and there is background noise, though seemingly worse for me than the other end as some haven't heard an issue. However no actual problems with the calls themselves. And no to your last question.
11-12-2014 12:24 PM
11-12-2014 12:47 PM
The SSFP link does work but it's slow to load. Try this Mk3 one. If you have a filtered plate, the phone socket is at the bottom and the modem/router socket at the top. The Mk1 is plain (no grey lettering) and the Mk2 says Mk2!
11-12-2014 12:52 PM
And yes I'm learning.
Also have to say a big up just now to phone support who have arranged now a weekend call out as Openreach are working the weekend in this area - which is abnormal for them.
