Anyone got lag this evening?
- Re: Anyone got lag this evening?
27-12-2012 8:36 PM
Gaming is a nightmare tonight. My Graph isn't showing anything unusual:
C:\>ping www.bbc.co.uk
Pinging www.bbc.net.uk [212.58.244.68] with 32 bytes of data:
Reply from 212.58.244.68: bytes=32 time=198ms TTL=54
Reply from 212.58.244.68: bytes=32 time=193ms TTL=54
Reply from 212.58.244.68: bytes=32 time=197ms TTL=54
Reply from 212.58.244.68: bytes=32 time=214ms TTL=54
Ping statistics for 212.58.244.68:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 193ms, Maximum = 214ms, Average = 200ms
Reply from 212.58.244.68: bytes=32 time=213ms TTL=54
Reply from 212.58.244.68: bytes=32 time=211ms TTL=54
Reply from 212.58.244.68: bytes=32 time=165ms TTL=54
Minimum = 165ms, Maximum = 213ms, Average = 200ms
C:\>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.246.95]
over a maximum of 30 hops:
1 73 ms 99 ms 98 ms dsldevice.lan [192.168.1.254]
2 25 ms 23 ms 12 ms lo0-central10.pcl-ag01.plus.net [195.166.128.182]
3 117 ms 16 ms 15 ms link1-central10.pcl-gw01.plus.net [84.93.249.0]
4 243 ms 245 ms 249 ms xe-0-2-0.pcl-cr01.plus.net [212.159.1.0]
5 149 ms 126 ms 125 ms ae1.ptw-cr01.plus.net [195.166.129.0]
6 122 ms 130 ms 133 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
7 * * * Request timed out.
8 222 ms 219 ms 204 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
9 99 ms 101 ms 98 ms 132.185.255.165
10 227 ms 237 ms 229 ms bbc-vip016.cwwtf.bbc.co.uk [212.58.246.95]
Trace complete.
My normal ping to BBC is about 11ms
_______________________________
Router Stats:
DSL Connection
Link Information
Uptime:28 days, 22:45:38
DSL Type:G.992.1 annex A
Channel mode:Fast
Maximum Bandwidth (Up/Down) [kbps/kbps]:1,164 / 8,000
Bandwidth (Up/Down) [kbps/kbps]:832 / 8,000
Data Transferred (Sent/Received) [kB/GB]:0.00 / 51.57
Output Power (Up/Down) [dBm]:12.0 / 19.5
Line Attenuation (Up/Down) [dB]:15.0 / 32.5
SN Margin (Up/Down) [dB]:15.0 / 6.0
Vendor ID (Local/Remote):TMMB / TSTC
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):139 / 0
FEC Errors (Up/Down):13 / 0
CRC Errors (Up/Down):302 / 22,563
HEC Errors (Up/Down):9 / 25,926
*EDIT* Actually its just starting to show at the end
Trace complete.
Router Stats:
DSL Connection
Link Information
Channel mode:Fast
Message 1 of 2
(798 Views)
1 REPLY 1
02-01-2013 10:50 AM
Message 2 of 2
(374 Views)
