Anyone Explain........
- Anyone Explain........
15-05-2009 12:23 PM
Looking around other Broadband Providers as I often do just to keep track of things I notice Virgin Media say they can provide a connection speed for me between 4.0Mbps to 5.0Mbps through a normal line (I'm not in a Cable area) yet Plusnet can only provide around half this speed no doubt due to the distance I live from my nearest BT exchange.
It may be that Virgin have LLU equipment in my nearest exchange but having read some of the problems associated with this type of equipment how is it Virgin can offer nearly double the speed of Plusnet.
Message 1 of 4
(861 Views)
3 REPLIES 3
Re: Anyone Explain........
15-05-2009 12:40 PM
I get the same , on my BE* line telle number i get my line is capable of 20.5mb on most checkers , knowing i have a 60db loss the figure is way out , BT should put something in place that can offer a reasonable estimate , not a figure double or even 4x like i get
Message 2 of 4
(356 Views)
15-05-2009 12:46 PM
Quote how is it Virgin can offer nearly double the speed of Plusnet
If Virgin do have LLU in your are and its ADSL2+ then its possible that they could provide better speeds.
In reality however the difference is more likely down to Virgin being VERY optimistic and PN using the standard BTw line checker which is pretty pessimistic!!
Message 3 of 4
(356 Views)
15-05-2009 1:08 PM
Kitz shows my "estimated" max speed as 4000 when its just about holding at 4500 at 48dB attenuation and a SNR of 7dB
So I suspect Virgin are just being very optimistic and will have the "Max speed is a completely wild guess and probably unattainable" get out clause.
Message 4 of 4
(356 Views)
