Any way to cap my broadband speed on ADSL2? (over ambitious profiling!)
- Any way to cap my broadband speed on ADSL2? (over...
- « Previous
- 1
- 2
- Next »
Re: Any way to cap my broadband speed on ADSL2? (over ambitious profiling!)
12-05-2012 10:26 AM
Quote from: Anotherone Have you tried an alternative modem/router and filter at the Test Socket to try and eliminate those possibilities?
12-05-2012 1:14 PM
Reference:
Release Notes for Vigor2820 series
Firmware Version : 3.3.7.1 (Release)
Release Date : 10th April 2012
Build Date : 29th Feb 2012
Applicable Models : Vigor2820, Vigor2820n, Vigor2820Vn, Vigor2820Vsn
ADSL Modem Code : 232201
Locale : UK Only / Annex A Only (inc UK Annex M)
NOTE: ADSL Modem Codes
For general purpose usage on UK lines, modem code 232201 is recommened
For ADSL2+ Annex M lines, the latest modem code 2471201 is suggested
For line speeds of less than 4Mbps, on lower quality lines a modem code with more conservative paramaters, 211801 is suggested
12-05-2012 8:06 PM
Might be an idea to run routerlite on your PC to monitor noise margin and connection speed. It handles a larger number of router/modems. Set it to capture graphs to jpegs (and maybe data to a logfile). You then get a visual indication of the ups and downs of your noise margin over time and can cross reference with the disconnections reported by Plusnet.
13-05-2012 10:28 AM
Unfortunately, it fails to stick at 6dB following an SNR reset, and eventually reverts back to 3dB after a few days.
PN now trying to apply an banded profile to my line to limit the line speed to no more than 6,656kbps for past week, but so far it has not worked at all and line speeds continue to hit as high as 7,800kbps during the day if I have to resync the router. Next review of my ticket is tomorrow.
If a banded profile is successfully applied, I am wondering whether DLM will eventually remove it after a few days given the above experience with the target noise margin failing to stay at 6dB over the past fortnight....
13-05-2012 4:54 PM
Quote from: zzZzz Unfortunately, it fails to stick at 6dB following an SNR reset, and eventually reverts back to 3dB after a few days.
That was the problem Plusnet/BT were having with my line. Fingers crossed they have sussed it this time. Have been at 6db for over a week.
14-05-2012 2:24 PM
Quote from: ClashcityRocker It's an annoyance that my broadband is useless until I reboot it again because of the silly profile it's given
What do you mean by the silly profile? Where are you seeing this profile?
Jojo
14-05-2012 3:11 PM
I suspect that when the margin drops this low the error rate goes through the roof and slows the throughput - but that's only a guess as the OP hasn't posted any CRC or other error figures for us to look at, just made a comment.
As the OP hasn't posted for 4 days, perhaps he's getting round to trying some of the suggestions that have been made days ago, like checking in the Test Socket, checking he's got the latest firmware, comparing error figures when it's "bad" with another modem/router, resyncing late in the evening and leaving it connected. There again, maybe the builders have cut him off altogether!
14-05-2012 3:35 PM
From the two sets of data posted this is the BAD scenario. When reporting a GOOD link, connection rate < attainable rate.
14-05-2012 4:06 PM
14-05-2012 4:31 PM
I would go along with your thoughts but in this case the figures do seem to correlate.
14-05-2012 4:34 PM
14-05-2012 4:43 PM
Without knowing the OP's version we can only guess.
- « Previous
- 1
- 2
- Next »
