Any way of improving my speed?
- Re: Any way of improving my speed?
29-06-2011 1:58 PM
Hi
I used to have 5-6mb now i get 3.3mb , i dont know if interleaving or anything else on my account is blocking me getting a higher sync or anything i can do my side.
Our DSL Connection Rate :4056 Kbps(DOWN-STREAM), 443 Kbps(UP-STREAM)
IP Profile for your line is - 3577 Kbps
Download speedachieved during the test was - 3076 Kbps
Uptime: 2 days, 14:21:50
DSL Type: G.992.3 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 988 / 3,912
Bandwidth (Up/Down) [kbps/kbps]: 443 / 4,056
Data Transferred (Sent/Received) [MB/GB]: 377.82 / 3.76
Output Power (Up/Down) [dBm]: 12.5 / 19.0
Line Attenuation (Up/Down) [dB]: 28.5 / 47.0
SN Margin (Up/Down) [dB]: 21.5 / 8.0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 157 / 0
FEC Errors (Up/Down): 46,496 / 0
CRC Errors (Up/Down): 1,345 / 19,865
HEC Errors (Up/Down): 29 / 10,066
Any tips?
Cheers all
Lee
Any tips?
Cheers all
Lee
Message 1 of 8
(1,250 Views)
7 REPLIES 7
29-06-2011 2:15 PM
Looking at your downstream attenuation and SNR I'm not sure you'll get much better than you are currently to be honest, 47dB is fairly high for attenuation and 8dB is close to the 6dB minimum for SNR. I'm not sure if the line state has changed but it seems likely if the speeds have dropped, as what you have currently is pretty much spot on for those figures. I guess the router's already in the master socket and everything else is filtered? If so it doesn't look like there's much can be done as things stand I'm afraid.
Message 2 of 8
(868 Views)
29-06-2011 2:22 PM
Hmm how did i get 6mb at one point? how does my snr go down?
cheers matt
cheers matt
Message 3 of 8
(868 Views)
29-06-2011 2:46 PM
I guess something's changed on the line unfortunately. With regard to SNR, the lower the better as far as speed goes - you could try using some kind of custom firmware if there's any available for your router, some of these allow the SNR to be specified but if it's at 8 already I can't see the speed going anywhere near 6Mb.
Message 4 of 8
(868 Views)
29-06-2011 2:57 PM
thanks for the reply matt
So is there an option of interleaving being turned off ? Will help my gaming
Actually could you check if its on in the first place
Again thanks for your help
Lee
Lee
Message 5 of 8
(868 Views)
29-06-2011 3:57 PM
Interleaving's currently off at the moment, not sure that turning it back on will help any really.
Is the router plugged in to the master socket (where the phone line enters the house) and is it plugged in via any extension cables? If you've moved the router from there to a different socket bear in mind that both internal wiring and extensions will add interference to the line and cause it to sync at a slower speed, that's a possible explanation for the change.
Message 6 of 8
(868 Views)
29-06-2011 4:15 PM
Message 7 of 8
(868 Views)
29-06-2011 5:45 PM
thanks alot for the help guys
Message 8 of 8
(868 Views)
