Any ideas why my connection is now slower?
- Any ideas why my connection is now slower?
04-02-2014 9:35 PM
Had my FTTC connection since the 7th of Feb and it has been rock solid. The HHub5 is indicated that the line is synced at 78.12 Mbps, and when I have done speed tests I would get back any where from 70-73 Mbps (Wi-FI) and on downloads I would get a speed up to 8.6 MB and it would stay around there. Everything has been great but on Friday evening my connection dropped and wouldn't sync at first. When it finally did the speed was really slow. Since then the connection has been back on for 3 days and 23 hours, but now on speed tests I get around 60Mbps (Wi-Fi) and 72Mbps (Wired) (that is also on BT speediest site) but on downloads I can't get anything higher then 6.5 MB, and even then it slowly creeps back down to 4.5 MB and sometimes goes lower. Any ideas why I can't get back to the normal download speed?
My monthly usage so far is 305GB, with my next bill due in the next few days. So I am guessing it will reset on the same day. Is this heavy usage, and would Plusnet throttle my downloads?
Thanks for any help and suggestions
Re: Any ideas why my connection is now slower?
04-02-2014 9:41 PM
That one is easy - no it won't have any effect and you aren't being throttled
Quote from: ScottJames My monthly usage so far is 305GB, with my next bill due in the next few days. So I am guessing it will reset on the same day. Is this heavy usage, and would Plusnet throttle my downloads?
04-02-2014 9:44 PM
Also it looks like I have a double post.
05-02-2014 11:21 AM
I did some more speed tests over Wi-Fi and Wired, and they came back at 65 Mbps (Wi-Fi) and 72 Mbps (wired). There has got to be some sort of management here because it doesn't make sense why my downloads have slowed down so much.
If someone at Plusnet could look in to this their end to make sure that everything is correct, then that would be great.
05-02-2014 11:24 AM
05-02-2014 11:34 AM
05-02-2014 1:57 PM
I have tried a whole host of sites. One site that always gave great download speeds is Apples Developer site which I would get any where from 8 - 8.6MB. Now I get around 4.5MB. I just don't understand why I get the results on the speed checker and the router is indicating that it is synced at 78.12 Mbps, but my download does not reflect this. I have tried to download items at different times of the day as well to rule out peak time issues, and it doesn't seem to make a difference.
When testing the line I have tried with all other wired and wireless devices disconnected and it doesn't seem to make any difference. The only other thing I can think of doing is to reset the HH5 back to factory settings. I just don't like to disconnect the line if I don't need to.
Thanks for the help
05-02-2014 2:02 PM
05-02-2014 3:07 PM
05-02-2014 3:38 PM
05-02-2014 3:40 PM
05-02-2014 7:14 PM
I am going to reset the router back to factory settings and see if that helps at all.
05-02-2014 8:06 PM
Just reset the HH5 back to factory settings and things seem to have returned to normal. Speed tests via Wi-Fi are hitting 71Mb, and just downloaded a large file from Apple Developer, and it went up to 8MB, and stayed there!
Hopefully that is the end of those issues for a while!
06-02-2014 11:03 AM
Glad things are looking up now. Let us know if we can be of any further help.
