Any idea why this happened - multiple loss of PPPoA connection
- Any idea why this happened - multiple loss of PPPo...
30-07-2010 10:57 AM
Routerstats shows no loss of connection and the connection speed hasn't changed which it would have done with a resync at that time in the morning
Quote Wed, 2010-07-28 16:21:37 - CHAP authentication success
Thu, 2010-07-29 08:26:09 - Administrator login successful - IP:192.168.0.4
Fri, 2010-07-30 02:01:49 - Initialize LCP.
Fri, 2010-07-30 02:01:49 - LCP is allowed to come up.
Fri, 2010-07-30 02:02:49 - Initialize LCP.
Fri, 2010-07-30 02:02:49 - LCP is allowed to come up.
Fri, 2010-07-30 02:03:45 - CHAP authentication failed
Fri, 2010-07-30 02:03:45 - LCP down.
Fri, 2010-07-30 02:03:49 - Initialize LCP.
Fri, 2010-07-30 02:03:49 - LCP is allowed to come up.
Fri, 2010-07-30 02:04:42 - CHAP authentication failed
Fri, 2010-07-30 02:04:42 - LCP down.
Fri, 2010-07-30 02:04:49 - Initialize LCP.
Fri, 2010-07-30 02:04:49 - LCP is allowed to come up.
Fri, 2010-07-30 02:05:32 - CHAP authentication failed
Fri, 2010-07-30 02:05:32 - LCP down.
Fri, 2010-07-30 02:05:49 - Initialize LCP.
Fri, 2010-07-30 02:05:49 - LCP is allowed to come up.
Fri, 2010-07-30 02:06:49 - Initialize LCP.
Fri, 2010-07-30 02:06:50 - LCP is allowed to come up.
Fri, 2010-07-30 02:07:50 - Initialize LCP.
Fri, 2010-07-30 02:07:50 - LCP is allowed to come up.
Fri, 2010-07-30 02:08:21 - CHAP authentication failed
Fri, 2010-07-30 02:08:21 - LCP down.
Fri, 2010-07-30 02:08:50 - Initialize LCP.
Fri, 2010-07-30 02:08:50 - LCP is allowed to come up.
Fri, 2010-07-30 02:09:49 - CHAP authentication success
Fri, 2010-07-30 02:59:49 - LCP down.
Fri, 2010-07-30 02:59:56 - Initialize LCP.
Fri, 2010-07-30 02:59:56 - LCP is allowed to come up.
Fri, 2010-07-30 02:59:58 - CHAP authentication success
Fri, 2010-07-30 09:20:38 - Administrator login successful - IP:192.168.0.4
Quote Noise Margin: 9.1 dB
Connection Rate: 3776 Kbps
Line Attenuation: 51.0 dB
Power: 19.1 dBm
Max Rate: 4064 Kbps
SF: 9015671
SF Errors: 90
Reed Solomon: 306532826
RS Corrected: 23588
RS Un-Corrected: 461
HEC: 78
Message 1 of 4
(832 Views)
3 REPLIES 3
Re: Any idea why this happened - multiple loss of PPPoA connection
30-07-2010 11:02 AM
Tried an alternate router?
Message 2 of 4
(340 Views)
30-07-2010 11:09 AM
No
The only other one I have is a Speedtouch 585v6 and I can fiddle with the noise margin on that as well but why would it be a router problem.
I have checked the router log back as far as the 13th June and this is the first time it has happened.
This is why I wondered if it was something at your end
Message 3 of 4
(340 Views)
30-07-2010 11:17 AM
Looking a bit closer, it looks like BT scheduled maintenance which often starts at 2am. You'll notice there are only two successful authentication attempts in there, the rest are failures between 02:01:49 and 02:08:21.
Message 4 of 4
(340 Views)
