Any current problems with the BT Speedtester??
- Any current problems with the BT Speedtester??
27-09-2012 10:58 AM
I tried to run a BT speedtest twice yesterday and have just tried again within the last 10 mins on all ocassions the tester appeared to run but then halted after the 100% test but before sending any results to server and hung and reported a error had occured.
Any thoughts ........... the BTSpeedtest site suggests if problem persists contact ISP (PN).
Ian
Re: Any current problems with the BT Speedtester??
27-09-2012 11:01 AM
27-09-2012 11:03 AM
27-09-2012 11:18 AM
just tried BT Speedtest again - failed again. If there is some one from PN on the forum
can you pick this up and let me know what is happening
Ian
27-09-2012 12:06 PM
27-09-2012 12:08 PM
You have to run the first test which just gives you your up and down speed and latency and then at the bottom of the results page you will find a Further Diagnostics button which runs the full test and gives you your IP profile.
27-09-2012 12:28 PM
PS. I trust you are all aware of the JRE security issues, oh and the tester can work fine with jre-6u33, 6u32 and 7u5 by the way.
27-09-2012 12:30 PM
just tried your link - rxd. system busy message will try it again later.
Hi spraxyt,
I'm on some auto update for Java so will have to check which version thanks
Ian
28-09-2012 5:15 PM
well left things for a day and guess what BT Speedtester appears to be working again but as usual PN
profile is lower than BT.
Anyone from PN able to nudge my PN profile up? 1.3 would be fine yes that's right only 1.3 but at these
speeds every little helps
Ian
01-10-2012 10:13 AM
I've replied to your other post regarding you speed profile http://community.plus.net/forum/index.php/topic,108062.0.html
08-10-2012 11:44 AM
Working: Java(TM) Plug-in 1.6.0
File: /usr/lib/j2re1.6-ibm/jre/lib/i386/libnpjp2.so
Version:
The next generation Java plug-in for Mozilla browsers.
Broken: (yep broken has two ... one comes from $HOME/mozilla/plugins ... the other from /usr/lib/firefox/plugins)
Java(TM) Plug-in 1.7.0_03
File: /usr/lib/jvm/java-7-sun/jdk1.7.0_03/jre/lib/amd64/libnpjp2.so
Version:
The next generation Java <http://java.sun.com> plug-in for Mozilla
browsers.
Java(TM) Plug-in 1.6.0_26
File: /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/libnpjp2.so
Version:
browsers.
So Java7 flavour is broken? ... anyone have details ... ie is there a Sun bug report?
08-10-2012 12:45 PM
