Any Issues in Whitburn / North East Region
GistHunter
Evening
After months of perfect service the bottom has dropped out of my d/l speed, any suggestions issues at present?
BT Wholesale test is
Download speed Mbps 0.38
Upload speed Mbps 0.25
Ping Latency (ms) 38.38
Cheers
Gist
13 REPLIES 13
Fixes: 159
Re: Any Issues in Whitburn / North East Region
Can you please gather and post all of the information requested in the "Speed Issues" thread at the top of this forum.  We can then take a look and advise further.
GistHunter
I would have done but have had no internet connection till this eve -- any ideas
Fixes: 159
Sounds like you might have a faulty phone line.
Have you got dial tone?
Is the line quiet?  Dial 17070 option 2.
If there are any problems there, then report a line fault to your phone provider, otherwise please post the information requested.
GistHunter
Ok so back on again
BT W/sale
0.37 Download (Mbps)
0.34 Upload (Mbps)
126.13 Ping Latency
Current line speed 3.8Mb  Cheesy
Link Information
Uptime: 0 days, 2:41:41
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,016 / 7,592
Bandwidth (Up/Down) [kbps/kbps]: 1,007 / 2,264
Data Transferred (Sent/Received) [MB/GB]: 366.23 / 2.52
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 19.0 / 35.5
SN Margin (Up/Down) [dB]: 8.0 / 17.5
Loss of Signal (Local/Remote): 131,073 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 262,144 / 0
FEC Errors (Up/Down): 1,436 / 4,521
CRC Errors (Up/Down): 184 / 0
HEC Errors (Up/Down): 614 / 0
Currently trying to download a video getting download of 221 KB/s
hope this helps
Gist
MatthewWheeler
Fixes: 479
Your speeds are lower then expected and the line is disconnecting alot as shown below
Can you go through our troubleshooter here?
https://faults.plus.net
 Matthew Wheeler
GistHunter
Not at moment I have no connection at all.  Posting this via phone
Fixes: 159
You can run the trouble-shooter from anywhere - it does not need to be performed "on" the service line.
Those stats look grim - the SNRM is highly elevated (18db?) and therefore your current synch speed is markedly reduced.  The Maximum attainable rate is also significantly below what one might expect on a line with the reported attenuation.
GistHunter
Trouble shooter complete - results are recommending  an engineer -
MatthewWheeler
Fixes: 479
You've reported that the telephone line is noisy during the troubleshooter?
Just confirming the line is noisy as if it is we have to address that first as it'll be causing the connection issues
 Matthew Wheeler
GistHunter
Yeah, lots of crackling on line
dratddestroyer
I don't want to state the obvious..
Did you hear crackling from the master socket test point with just a phone plugged in?
I had a duff microfilter and when phone only plugged in to test socket line was perfect.
Chris
Legend
Fixes: 169
I've just replied to your fault ticket, when you get chance can you have a look and let us know that you've done the tests and what your availability for an engineer is?
GistHunter
So I sourced two corded phones from work and carried out further tests as required - the crackling sound is evident when plugged into master socket (without a micro filter)
I've already completed the section on when an engineer can visit -- the afternoon slots 1300-1800 as I'm in the office mornings
You might want to reassess your procedure whereby you send email notifications to an user who has no internet rather than just telephoning the number that had already been provided
Gist
