Another weird speed problem
- Another weird speed problem
09-11-2011 9:28 AM
Now my Internet connection is virtually unusable and it has to serve a large household. Iplayer is completely unusable. youtube buffers for 30s then plays 1s, then buffers for 30s, etc etc... Even small web pages take forever to load.
I had a similar issue a few years ago and it took years for speeds to recover. I am still on ASDL1 BTW.
BT speedtest shows download speed of 1.3M with an IP profile of 1500Kbps but the connection "feels" like dial-up. Exchange status shows green.
Re: Another weird speed problem
09-11-2011 2:49 PM
Kitz, how to get [color=red]line stats
The BT PT
09-11-2011 2:57 PM
If you can let me know if/when you can plug it into the test socket then I can run some checks for you. The SNR will have gone up to 12dB as a reaction to some interference. This could be caused by internal wiring or something external. The test socket will help us eliminate the internal wiring as a cause. Also, the sync rate won't slow, there will have been a drop, but that can be short and easy not to notice.
Jojo
09-11-2011 3:43 PM
The router is plugged directly into a filtered faceplate in the NTE5 master socket. Apart from one phone there is nothing else connected and no other internal extensions. I am not at home right now so can't change anything but I don't think there is anything wrong with my wiring.
FWIW my router reports DSL uptime and, after the slowdown but before I rebooted it, it was showing 812 hours uptime. It doesn't usually get this wrong.
I still don't think it explains the 12dB SNR target margin as I thought this should only go up after many problems and only in 3dB steps.
I had a similar issue a year or two ago when the line would drop once only and the margin would be up from 6 to 12dB. Back then I used to monitor the connection 24/7 so I could see there were no other problems. I had stopped doing this recently since I hadn't experienced any issues for a while -- typical
I don't get very good speed at the best of times so this is a major blow.
09-11-2011 5:23 PM
09-11-2011 5:51 PM
10-11-2011 8:20 AM
have you been able to do that?
Jojo
10-11-2011 8:24 AM
10-11-2011 8:41 AM
10-11-2011 9:11 AM
10-11-2011 1:29 PM
10-11-2011 1:38 PM
That seems to have worked. I've just raised your profile to 2500, so you should see that shortly.
Jojo
10-11-2011 2:01 PM
10-11-2011 3:21 PM
10-11-2011 3:24 PM
