Another question on the Netgear fibre router (WNR1000v3)
- Another question on the Netgear fibre router (WNR1...
13-02-2012 1:33 PM
Re: Another question on the Netgear fibre router (WNR1000v3)
13-02-2012 3:43 PM
On the left hand menu under advanced you should just have to go to LAN setup and then add a device from there.
Jojo
13-02-2012 3:49 PM
14-02-2012 11:45 AM
Just thought I'd let you know I've replied to your ticket
14-02-2012 1:19 PM
I don't need advice on how to set it up or be "guided" through the process.
I thought this would be perfectly clear from my ticket and the posts I have made to the forums. (I've set up loads of routers and other network hardware without encountering any similar problems.)
I am certain that these routers have one or more bugs preventing me from achieving the desired outcome.
There seems to be two main problems in this area:
Netgear won't support the router as it has custom firmware and you also don't want to do so. So I have a router which has a problem for which no-one will accept responsibility.
EDIT: I have added two files to the ticket which clearly show the problem.
14-02-2012 2:12 PM
It seems strange that it's not picking up the Device name either (I've got IP reservations in my Netgear and they're working), but then again I haven't adjusted the DHCP range from the default (if I remember tonight I'll give this a test and see if it keeps the reservations).
14-02-2012 2:24 PM
15-02-2012 11:59 AM
Unfortunately Chris isn't in the office today so I don't know if he's been able to test as above, I'll check with him as soon as I can and let you know what's going on.
15-02-2012 1:00 PM
Another thing; not only does it not allocate the correct addresses as shown on my ticket but it may decide to allocate a "reserved" address to a different device. Therefore it seems to behave as if the reservations were not there at all.
20-02-2012 10:24 AM
20-02-2012 10:50 AM
