Another case of SLOW in last 24 hours
- Another case of SLOW in last 24 hours
29-02-2012 3:00 PM
1. Best Effort Test: -provides background information.
Download Speed
2.68 Mbps
0 Kbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 2.68 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 7.85 Mbps
As with Mandoo http://community.plus.net/forum/index.php/topic,103009.0.html I am wondering if something is up with BT at the moment.
Sync etc is very good for my ~3km line too.
Link Information
Uptime: 1 day, 1:32:12
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 440 / 8,897
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 25.0 / 46.0
SN Margin (Up/Down) [dB]: 20.5 / 2.5
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 9 / 0
FEC Errors (Up/Down): NA / 31,137,334
CRC Errors (Up/Down): NA / 1,277
HEC Errors (Up/Down): 0 / 1,103
As with Mandoo
Upload Speed
373 Kbps
0 Kbps 448 Kbps
Upload speed achieved during the test was - 373Kbps
Additional Information:
Upstream Rate IP profile on your line is - 448 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
We have identified that you have additional services enabled on you broadband line, please click continue to run advanced service tests.
Re: Another case of SLOW in last 24 hours
01-03-2012 8:23 AM
I take it they were wired results rather than wireless? Are you getting this speed constantly or is it only certain times of the day?
Jojo
01-03-2012 9:43 AM
Wired!
On 28/2 throughput during evening was down to <2Mb/s; yesterday 29/2 (see above) 2.68Mb/s and a few minutes ago 4.17Mb/s per BT speed tester on current sync 7929kb/s.
Below are also results from PN's My Broadband Speed
At other times it appears to have been within 90% of IP Profile
Quote Date Download Speed Upload Speed
Today 09:46 6816 kbps (852kB/s) 370 kbps (46.3kB/s) Share
Tuesday 22:45 6880 kbps (860kB/s) 362 kbps (45.3kB/s) Share
Tuesday 19:37 3963 kbps (495kB/s) 351 kbps (43.9kB/s) Share
Tuesday 17:57 2316 kbps (290kB/s) 371 kbps (46.4kB/s) Share
Tuesday 17:50 1605 kbps (201kB/s) 361 kbps (45.1kB/s) Share
Tuesday 17:49 1653 kbps (207kB/s) 372 kbps (46.5kB/s) Share
Tuesday 17:49 1635 kbps (204kB/s) 372 kbps (46.5kB/s) Share
Tuesday 17:48 1572 kbps (197kB/s) 372 kbps (46.5kB/s) Share
Tuesday 17:48 6869 kbps (859kB/s) 369 kbps (46.1kB/s) Share
Tuesday 17:47 6468 kbps (809kB/s) 370 kbps (46.3kB/s) Share
Tuesday 17:47 2906 kbps (363kB/s) 373 kbps (46.6kB/s) Share
Tuesday 17:46 2450 kbps (306kB/s) 370 kbps (46.3kB/s) Share
hope it all may inform.
01-03-2012 2:58 PM
Do you know what target noise margin is set on your line ? If it is 3dB, perhaps it is too low a setting for your line.
It could be noise on the line, which would be at its worst from around 6pm onwards usually.
Have you tried connecting router to the test socket?
01-03-2012 6:14 PM
Anyways the question is not with sync but throughput. Sync is no problem ~9000 for a mid morning boot, which reduces to ~8000 if there is an evening resync. So it has been since some months ago, when BTo repaired a fault in the underground street cables.
Since then target SNR appears to be 3-3.5 and attenuation 47 until a week or so back, now 46. According to PN interleaving is on.
As to noise, it must be something recent and there is nothing around I can think of. We back on to New Forest, away from anything likely. Today16.20 18.10 download MyBBS is 6816.
The error rate. if on fastpath how could there be FECs?
01-03-2012 6:21 PM
01-03-2012 6:44 PM
02-03-2012 9:40 AM
Quote from: lucerne Below are also results from PN's My Broadband Speed
Have you got results from another speed tester as mybroadbandspeed is giving unreliable results at the moment.
Jojo
02-03-2012 11:10 AM
TBH I am wondering if the slow speed was not out of some special circumstance that evening, that has remote chance of repetition.
For my connection the only additional use in the last week has been occasional use of IPlayer via HomePlugs: I don't think it was active at the time.
I will monitor the situation. Maybe we should put this thread on hold for the time being. I shall come back if something happens again.
02-03-2012 2:58 PM
02-03-2012 4:42 PM
Quote from: Joanne ... don't rely on mybroadbandspeed for the results at the moment
Found that out too - speedtest.net is working though.
04-03-2012 2:40 PM
06-03-2012 10:50 AM
We're not exactly sure of timescales at the moment, and I don't believe it's a simple fix either, but as you can imagine it's something we are eager to resolve.
Jojo
