Another Airport Extreme connection problem
- Another Airport Extreme connection problem
Re: Another Airport Extreme connection problem
05-06-2014 1:12 PM
I called the BT engineer from yesterday and he said that as the green light is turned on on the modem then everything is working correctly up to that point so it seems that it stops there.
05-06-2014 1:17 PM
05-06-2014 1:21 PM
05-06-2014 1:24 PM
You need to first uncheck the attachments then you can upload them again
05-06-2014 1:27 PM
05-06-2014 1:46 PM
There's a couple of things that could be causing the problem,
1) Your installation has not been completed correctly by BTOR, i.e the routing to PlusNet hasn't been completed and so your PPPoE connection fails.
2) Your PlusNet account hasn't been activated
I would have thought that Chris can quickly check those...
05-06-2014 2:03 PM
Always something that goes wrong.
05-06-2014 3:07 PM
Ideally I'd like to get this resolved today
05-06-2014 3:37 PM
Bit of a long shot, but under Internet Options, have you tried setting IPv6 to "Link Local Only"?
IPv6 implementation is odd at the moment and may break things...
05-06-2014 3:44 PM
Quote Sorry to be a nag but has anyone from Plusnet been able to look at this for me?
Try dropping Chris a PM
05-06-2014 3:47 PM
From what I can see you seem to have the configuration of the airport correct so this is a tough one to diagnose
I think the best course of action would be to raise a fault here if you're unable to get a connection to the internet by using an ethernet cable directly connected between the BTO modem and laptop/PC. Failing this it may be a call to Apple support to run through the settings on both the Airport and computer to rule out any software/hardware issues.
05-06-2014 3:50 PM
Are you not able to see any pings coming from my username your end? Just to see whether there is anything actually going to your end.
05-06-2014 3:51 PM
Do the logs show any activity from the OP which confirms that PN are seeing login attempts?
05-06-2014 3:59 PM
As I've said before, the green light is definitely on and stable on the modem just no connection when trying to connect via PPoE from either the Airport router or through my MacBook and setting up a PPoE connection
05-06-2014 4:32 PM
