Ambiguous Peak Times from PlusNet
- Re: Ambiguous Peak Times from PlusNet
03-08-2007 8:45 AM
Hello All,
For the PlusNet service I have, it says that I have free bandwidth between midnight and 8am and a cap of 20GB at other times.
However, if I log into the member portal and look at my usage, it shows peak time as between 4pm and midnight.
Does anyone know which it is?
Thanks,
Phillip Eaton
St Albans, UK
Thanks,
Phillip Eaton
St Albans, UK
Message 1 of 5
(2,816 Views)
4 REPLIES 4
03-08-2007 8:49 AM
It depends on which package you're on.
Regards .....
Regards .....
Message 2 of 5
(1,198 Views)
03-08-2007 8:52 AM
Quote from: lingbob It depends on which package you're on.
Regards ...
I'm on ADSL Home Surf at 18.99pcm. I've been on this since 2003.
Message 3 of 5
(1,198 Views)
03-08-2007 9:44 AM
That is one of our legacy packages, where the peak is indeed 4pm - Midnight.
The product you are looking at is our new Broadband Your Way Option 3 @ £19.99/month which comes with 20GB Usage Allowance between 8am - Midnight and free overnight usage.
You may find it beneficial to upgrade to that package for the extra £1/month depending on your usage habits - as it does have some better features and you're not restricted using P2P / Binary Usenet. You may also be able to downgrade to Option 2 @ £14.99 and save yourself some money. Depends entirely on your usage - but the new products are worth a look and it's free to change should you wish.
Message 4 of 5
(1,198 Views)
03-08-2007 9:56 AM
Quote from: Liam That is one of our legacy packages, where the peak is indeed 4pm - Midnight.
Ah, result, I think I'll stay where I am. I prefer to have 16 hours off-peak instead of 8
Actually, the most important thing to me is the static IP, but I also need to transer several large files occasionally, so my package still works for me.
Thanks for your help,
Phillip Eaton
Message 5 of 5
(1,198 Views)
