Am i able to go on ADSL2+ ?
- Am i able to go on ADSL2+ ?
11-01-2012 5:14 PM
Hi guys
Im wondering if im able to be moved onto adsl2+ im on adsl2 now i think, dont know if im on 21cn is it either.
i was on adsl2+ early in the year if i remember was syncing at around 5500 ish
Would appriciate the help
Lee
Oh here are my stats :
Link Information
Uptime: 4 days, 21:14:01
DSL Type: G.992.3 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 992 / 4,120
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3,864
Data Transferred (Sent/Received) [MB/GB]: 362.50 / 4.77
Output Power (Up/Down) [dBm]: 12.5 / 19.0
Line Attenuation (Up/Down) [dB]: 28.0 / 46.5
SN Margin (Up/Down) [dB]: 22.0 / 10.0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 3 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 70 / 5,486
HEC Errors (Up/Down): 19 / 13,110
Lee
Link Information
Message 1 of 3
(785 Views)
2 REPLIES 2
Re: Am i able to go on ADSL2+ ?
11-01-2012 5:25 PM
Your default noise margin has increased from 6dB to probably 9dB or even 12dB and this could easily explain the speeds.
However even with this noise margin your speeds are a bit low.
Can you try the router in the test socket - moved during daylight hours for the best result - and report the stats again.
The reason you are on ADSL2 and not ADSL2+ is that with your line length as reported by the attenuation you wouldn't benefit from the higher frequencies used by ADSL2+
Message 2 of 3
(384 Views)
11-01-2012 5:33 PM
Great reply jim thanks a bunch mate
Message 3 of 3
(384 Views)
