Am I stuck with 4000mb?
- Am I stuck with 4000mb?
23-09-2011 10:47 PM
or is there a way of upgrading I’m unaware of?
I’m on extra btw.
Re: Am I stuck with 4000mb?
23-09-2011 10:55 PM
http://community.plus.net/forum/index.php/topic,96155.0.html
24-09-2011 5:14 PM
Doing that test was what brought me to the conclusion that 4mb was all I was going to get.
Here are my results, I was unable to check the router as my Buffalo WBMR-G54 wasn’t listed.
Download speed 4036 Kbps
Max Achievable Speed 4000 Kbps
Speed during test 4036
Connection range 1200 – 4000
DSL connection rate 4992 (down) 448 (up)
Ip profile for line 4404
Upload Speed 364
Max Achievable Speed 448
24-09-2011 5:26 PM
alternatively Page 98 of the manual http://www.ccsleeds.co.uk/KB/Routers/Wireless_ADSL_Router_WBMR-G54_Manual.pdf (page 108 0f the pdf file)
24-09-2011 5:55 PM
ADSL status shows the ADSL physical layer status.
ADSL Firmware Version: 6.00.01.00 - 6.00.01.00 - 6.00.04.00 Annex A - 01.07.2b - 0.54
ADSL Software Version: V3.00B01T01.20060721
Line State Connected
Modulation ADSL_G.dmt
Annex Mode Annex A
Max Tx Power -38 dBm/Hz
Item Downstream Upstream Unit
SNR Margin 14 23 dB
Line Attenuation 38 23 dB
Data Rate 4992 448 kbps
24-09-2011 6:05 PM
For some reason your default noise margin has increased to 15dB either because of massive errors on the line or perceived instability.
Once the staff come back in on Monday they should be able to provide a disconnection chart and, if appropriate, initiate a line reset to 6dB noise margin.
In the meantime can you describe your internal setup in relation to how the router is connected to the telephone system.
Are you using the master socket or an extension.
This may be worth a read http://www.kitz.co.uk/adsl/socket.htm
24-09-2011 11:29 PM
But not wanting to rule anything out I did connect straight to the master socket via a splitter tonight and the reading matched what I was getting from the extension.
I am noticing that my SNR is fluctuating it’s been as low as 2, and the data rate has dropped by about 600 tonight.
I can’t see a line reset making a big impact on the download speed, I’m looking for something that can take me into the 6000 region.
Is ADSL2 an option? I believe I was offered it on my last contract (the name escapes me but it only had a 15gb cap) but It’s not been offered since changing to extra.
I also switch the router off every night, could that be showing as disconnects?
26-09-2011 10:39 AM
Quote I can’t see a line reset making a big impact on the download speed, I’m looking for something that can take me into the 6000 region.
That is because you haven't appreciated the effect of a 15dB default noise margin
This is why you have a 15dB default noise margin
Quote I am noticing that my SNR is fluctuating it’s been as low as 2, and the data rate has dropped by about 600 tonight.
You need to look first at your internal wiring.
I would recommend connecting the router to the test socket and monitoring the noise margin
26-09-2011 10:43 AM
Although the extension may be physically ok, they can suffer when it comes to interference. As Jim says, connect it to the test socket. Once you've done that I'll set your SNR to 6dB and we can see how it goes from there.
Jojo
26-09-2011 10:56 AM
26-09-2011 11:04 AM
You need to monitor the noise margin as before to see if it remains stable and doesn't drop to low levels
26-09-2011 11:26 AM
do I have a test socket.?
26-09-2011 11:58 AM
26-09-2011 12:02 PM
26-09-2011 12:06 PM
Is that the only socket in the house?
Jojo
