Am I going to be unhappy ?
- Am I going to be unhappy ?
Re: Am I going to be unhappy ?
21-05-2012 3:36 PM
21-05-2012 3:41 PM
21-05-2012 3:45 PM
21-05-2012 3:50 PM
21-05-2012 3:54 PM
Any opinion on my question regarding clicking on Disconnect on my router page? You say that this would not let the DLM think one was having probs or something similar.
21-05-2012 4:02 PM
If you've got to strain to hear any hiss or mush, then the line is probably ok.
Now as it's a cordless phone, you could try this as long as RouterStats is running and you can see the graph. Switch off the handset and switch off the power to the base station, but don't do any thing else, and see what happens to the noise margin on the graph.
21-05-2012 4:15 PM
Are you confirming that there was yet another resync to day whilst I was not using the PC and the router is never switched off?
21-05-2012 4:19 PM
21-05-2012 4:31 PM
I can't tell how many resyncs you may have had, only that one occurred at about 1310 based on the stats page you've posted and the time you posted it.
Can you look at the Uptime on the Internet section, near the "Disconnect" button and post that? but if you powered down using the disconnect procedure that probably won't be any help now.
Can you post the Noise Margin graph again - if the margin is creeping up again, that would have accounted for the improved sync speed.
21-05-2012 4:42 PM
21-05-2012 4:54 PM
Being on 20CN myself I fully understand your frustration when things aren't going right.
21-05-2012 4:57 PM
21-05-2012 5:08 PM
21-05-2012 5:20 PM
It's unlikely to have been a power dip that caused the resync as I would have expected both times to be the same if the modem/router had rebooted due to a power dip. So it was either DLM (possible) or a burst of noise - also possible. Did you look at the RouterStats graph before you changed the filter? If so, what had happened to that downward trend that was there in the 3pm graph, had it gone back up and levelled off as per the latest graph?
21-05-2012 5:25 PM
