Am I going to be unhappy ?
- Am I going to be unhappy ?
Re: Am I going to be unhappy ?
26-05-2012 1:10 PM
26-05-2012 1:25 PM
[tt]cat /proc/avalanche/avsar_ver
ATM Driver version:[7.03.01.00]
DSL HAL version: [7.03.01.00]
DSP Datapump version: [7.03.01.66] Annex A
SAR HAL version: [01.07.2c]
PDSP Firmware version:[0.54]
Chipset ID: [Ohio250(7200/7100A2)][/tt]
26-05-2012 2:28 PM
27-05-2012 8:21 AM
Please note that Noise has been at 7 for a couple of days now not at 9. I also attach latest Router Status info.
BT Speedtest still DL 0.70 & IP 0.75.
Regarding 10 days, as I thought it will be from the last re-set not from initial installation day.
27-05-2012 9:57 AM
If you can post some of today's Noise Margin plots I'll have a look again around 12-1pm ish if all is looking stable, a Disconnect/power down/wait 10 mins/power up resync may be on the cards to get the sync back above 1152.
28-05-2012 10:18 AM
Attached is the latest Noise Margin graph after running RouterStat since 7.a.m today. Also did a BT Speedtest to check my IP & DL details, also attached.
Should I go ahead and do a Disconnect/Power down now?
Please note the Noise Margin attachment should read 28May not 29 May.
28-05-2012 12:12 PM
28-05-2012 3:21 PM
Difficult to say without those and especially if DLM is playing about!
Edit: The only plus is that your profile hasn't gone lower.
28-05-2012 4:52 PM
To date I have experienced 6.1db thru to 9db and 1120kbps since 16May. Changed to Netgear router on 22May and had 6db and 1344kbps. Since then it has been a mixture of results from a IP profile twice of 1mb and a DL of 0.93 ( both lasting 24hrs only) to 9db and 992 kbps.
I attach the last Noise Margin upto the time I powered down, showing a steady and consistent 7-6db fluctuation, and the latest very brief level over the last 20 minutes.
28-05-2012 5:10 PM
These spikes are bothering me, especially when they give a 2 dB dip, as well as the other longer dips.
28-05-2012 5:17 PM
28-05-2012 5:21 PM
29-05-2012 9:52 AM
forgive me if you've stated this before but are you currently in the test socket?
Jojo
29-05-2012 10:10 AM
"Anotherone" has been monitoring my situation. For the recent past I was having Noise Margin of 6-7db and connection speed of from 1184 to 1344kbps. After the powerdown I am stuck on Noise Margin 9db and RX Sync of 928.
I believe I am now at the end of the Testing period and am looking for an improvement back at least to a 1mb IP profile and at least 0.93 DL.
Are you planning any possible action from your (PN) end?
29-05-2012 11:06 AM
Thanks.
