Alternative Router Options?
- Re: Alternative Router Options?
21-08-2014 2:16 PM
Hi Guys,
Just wanted to know if there are any good alternatives to the TG528n. There isn't anything overly negative about the Technicolor, however I've noticed that the 100mbps connection is a bit, well slow, and I want to improve overall throughput and Wireless connectivity. There are a few caveats, it needs to be able to work with a Vodafone Sure Signal v2 and it needs to be compatible with Youview Multicasting. I have tried a Home Hub 5 which works fine with Youview but the Sure Signal is a cop out. I'd also like to do away with the Openreach Modem. It's not a big issue, but it's just another device chewing electricity...
Now the kicker, don't want to be spending Draytek money. £200 for a home Router is a bit more than my budget would stretch to, in fact I'd be cringing at £100....
Any idea is a good idea.
Message 1 of 7
(1,755 Views)
6 REPLIES 6
21-08-2014 2:59 PM
Your options are fairly limited for a VDSL modem/router for less than £100.
I would have suggested the Home Hub 5, but you've already tried that so that one isn't much use.
You might be able to pick up an Asus DSL-N66U for less than £100 soon.
Message 2 of 7
(870 Views)
21-08-2014 3:11 PM
As Andy mentions choices are limited for routers with integrated VDSL modems under £100. So probably best to stick with a two box solution.
If the Asus routers are too pricey take a look at TP-Link.
I use a TP-Link WDR3600 (and am currently using it on the YV trial, so know it handles multicast no problem) and would highly recommend it for the under £50 you can get it for now (I paid nearer £80 iirc)
Message 3 of 7
(870 Views)
21-08-2014 3:38 PM
If you don't need the latest greatest then you can get e.g. the Asus RT-N56u (router only) for £66. It's got pretty good reviews. If you want one with a VDSL modem built in, then I think you need the next model up, (DSL-N66u) which boosts the price to an impressive £116 - you'd need to chew an awful lot of electricity to make that pay for itself!
Message 4 of 7
(870 Views)
21-08-2014 5:51 PM
You could try a Talk Talk super router HG635.
Don't know if it works with the Vodafone Sure Signal but it meet all your other requirements.
£30 to £40 from a on-line auction site.
Some details here: http://npr.me.uk/hg635.html
Message 5 of 7
(870 Views)
22-08-2014 9:27 AM
Another recommendation for the WDR3600 the 2 TG582N I've got suffer with wifi problems with apple products
Message 6 of 7
(870 Views)
24-08-2014 4:23 PM
Hey,
Well I bit the bullet and got the TL-WDR3600..... So far it seems to do the job without any hassles which is always a bonus! I have found an odd issue though. With previous routers I have simply pointed to them for primary DNS and that has allowed all the devices to be resolved by hostname. However I have found that this doesn't seem to be the case. Does it not have a built in DNS Resolver (like DNSMASQ or BIND)? I am sure there is a way around it but it's just not clear as to how I would change things without having another machine as a DNS server.
Any help?!
Any help?!
Message 7 of 7
(870 Views)
