Airport Extreme
- Airport Extreme
Airport Extreme
07-08-2007 1:26 PM
Both the airport and the broadband (using voyager) work independently of each other. Nothing else has changed, they have just stopped working?
Re: Airport Extreme
07-08-2007 1:38 PM
Re: Airport Extreme
07-08-2007 1:43 PM
Like I say the Voyager still works correctly when plugged straight into my computer.
Re: Airport Extreme
07-08-2007 1:44 PM
Does the airport have a feature to ping out? If so can it ping the voyager?
Re: Airport Extreme
07-08-2007 2:13 PM
Re: Airport Extreme
07-08-2007 2:14 PM
Re: Airport Extreme
07-08-2007 2:17 PM
Forgive my ignorance, but is the voyager just a modem and the base station (if used) the wireless transmitter?
It could be your airport card that's stopped working, hence the two still work separately.
I guess at worst, you could replace both with one Broadband Router/Modem device.
How about the ethernet cable between the two (I assume that's what connects them). You could try another cable just to see if it's that that's at fault.
Re: Airport Extreme
07-08-2007 2:32 PM
Nope, no particular reason, this is just what my IT department supplied me with. Are you saying that I could just plug the dsl cable from the telephone straight into the Airport?
Re: Airport Extreme
07-08-2007 2:36 PM
Happy to replace it with something that works, yes. Can you recommend a single Broadband Router/Modem device.?
Re: Airport Extreme
07-08-2007 2:37 PM
Re: Airport Extreme
07-08-2007 2:52 PM
I've had it for about 20 months and no real probs except some minor setting up and learning about port forwarding to open up some ports for xbox live etc.
Re: Airport Extreme
07-08-2007 2:53 PM
Great router, can be picked up for quite cheap too if you know where to look
