Again and Again and Again
- Again and Again and Again
30-06-2010 6:51 PM
I have just raised a ticket for the 3rd time this month .Today my speed dropped dramatically again.Well I have just about had enough and seriously considering that it's maybe time to move on.
Router Stats
WAN PPPoA 45801 50429 0 577 1740 04:48:40
LAN 10M/100M 258599 0 0 37 0 387:43:47
WLAN 11M/54M 2148452 2062040 0 1017 251 387:43:38
ADSL Link Downstream Upstream
Connection Speed 160 kbps 448 kbps
Line Attenuation 55 db 15.5 db
Noise Margin 9 db 18 db
BT Speed Test
Hope I haven't got to put up with this for another week.
Router Stats
BT Speed Test
Message 1 of 8
(1,216 Views)
7 REPLIES 7
Re: Again and Again and Again
01-07-2010 9:45 AM
HI dennisb66,
Can you confirm whether you're in the test socket and have tried changing the microfilter. Once you have I'll do some checks for you.
Jojo
Jojo
Message 2 of 8
(684 Views)
01-07-2010 11:50 AM
Hi jojo
Yes still in main test socket.Have just changed filter as requested.
BT Speed Test
Download speedachieved during the test was - 687 Kbps
For your connection, the acceptable range of speeds is 200-1000 Kbps.
Additional Information:
Your DSL Connection Rate :2720 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 750 Kbps
I have had no reply from yesterays ticket yet. Wave your magic wand Jo, ha ha
BT Speed Test
Message 3 of 8
(684 Views)
01-07-2010 12:02 PM
Hi dennisb66,
Sync speed is a lot better with that configuration. If it stays like that the profile will soon lift.
Jojo
Jojo
Message 4 of 8
(684 Views)
01-07-2010 12:26 PM
Yes I noticed that my connection rate had risen,do you think that all this time it was the filter causing the problem.
Message 5 of 8
(684 Views)
01-07-2010 12:30 PM
If that's the only thing that has changed then it may well have been.
Jojo
Jojo
Message 6 of 8
(684 Views)
01-07-2010 12:52 PM
You'd think that a simple electronic thing like a filter would last forever, but failing ones do seem to cause a fair number of problems.
Message 7 of 8
(684 Views)
01-07-2010 8:35 PM
I think the number of problems caused by failing filters is minuscule by comparison to the number of problems caused by people forgetting to fit filters on all their telephones or on the phone line that goes to their sky box, or plugging the fax machine into the ADSL side of the filter or because they have had lots of extension sockets fitted, all with the bell wire connected. I have seen all these whilst out and about on my travels fixing computers.
Of course, if dennisb66's original results were taken plugged into the test socket and only the filter has changed then it must be the filter.
Message 8 of 8
(684 Views)
